Update: Pentosin FFL3 was the correct fluid and fixed most of my issues.
6MT Spec 3+ SMFW. no CDV. When cold out (<40*) the transmission doesn't like to go into 1st without either:
I have Amsoil MTF which is more viscous (9.7 cSt at 100C) than ZF specification for the gearbox, which I'm sure is not helping the problem. https://bmw.spoolstreet.com/threads/smfw-chatter.2110/#post-21962
Should I order additive, or new fluid? I've had Redline D4 before and didn't like it, shifts were notchy especially 3rd gear. Notchy shifts and the fact that I race the car (autox/drag/road course) is why I switched to a thicker fluid.
- car slowly moving forward (if on smooth ground and no brakes, the car will actually roll forward with clutch fully depressed as I try to put it in 1st)
- engaging 2nd beforehand
- hamfisting it (significant force)
