Hey guys, Dave from Ambient Thermal Management here. I am one of the new owners of ATM and just wanted to share some of the technical information of our legendary E9X FMIC with you. ATM has been dormant so it's been a while since our data has been posted. Here are some of the details:
SIZE- We've measured the available area in front of the bumper in both depth and height and custom designed an intercooler that makes the most of this space - the result is an intercooler with 56% more frontal area and 56% more core volume than stock.
CORE- ATM is the only FMIC manufacturer producing a stepped core as one single assembly. Our core is custom made to our specifications, including the ambient and charge row height and internal and external fin count. And of course, at the heart of every ATM intercooler core is our unique rounded header bars which act as a velocity stack for the charge rows, increasing the flow efficiency from 80% to 98%.
PLUMBING- ATM opted not to utilize the factory plumbing. The reasoning is simple: the E80/90 series cars utilize restrictive charge pipes that shrink down to less than 2" ID. Our intercooler kit uses 2.5" ID silicone charge pipes and a 2.5" OD aluminum J-Tube (2009+ vehicles).
ENDTANK DESIGN- All endtanks are not created equal. Air likes to flow in a smooth, curved radius just like you see on the rounded cast endtanks of the ATM FMIC.
The end result is the ATM FMIC's ability to remove more temperature, meet the targeted air flow, and minimize pressure drop in your BMW.
And as you can see, we're now offering additional finish options! Black or silver powdercoat.
Now for the stuff you want to see, here's the data showing the high efficiency of our infamous FMIC core:
And as many of you know, there are a number of independently-tested logs across the web showing the high efficiency of the ATM core. Here are a few:
And 4th gear WOT
And 4th gear WOT
