Tablet recommendations for in-car
3,642
Ok I'm disillusioned with the Avin / etc units. I don't want to integrate old crap into my car. So that said, I'm non-iDrive and thinking of just mounting a tablet. I'm not up to speed on what to care about (size is obvious). Are there brands/models/features I should consider or avoid?
I want to run Torque, MHD, maps, and might do some audio aux out with Spotify.
Thanks,
NoQuarter
1,662
1,067
Indiana, USA
Z4 35is, 535xi, X5 35i
You will have more options and flexibility if you can separate the display from the Android device.
Perhaps a nice HD display that you make look good on the install then an Android mini device with an HDMI output?
3,642
That's crazy talk. lol. I had not thought of that. Good idea.
My current brain fart - Galaxy Note 8 with Qi charging, with a spring-loaded hinge in the flip-up cubby hole. Qi charger for power, USB BT dongle does Torque, OTG/USB could switch in for MHD (isn't BT coming for MHD?), aux for sound cellular for full connection.
1,285
779
@N54gasm nailed it - the Nexus 7 with Timur Kernel is probably still the best performing tablet you can get hardware wise.
With that being said, as much as I don't like the old android version and screen resolution of the Avin units, the integration is kinda nice. Since you are non-IDrive, have you seen the one that is F-style that you have to cut the dash to install, and it gives you the 10inch screen? You'd keep the stock radio, and use aux in just like the idrive ones, but it looks much nicer install than just slapping a big tablet on the dash.
https://avinusa.com/10-25-bmw-1-series-e81-e82-e87-e88-multimedia-navigation-system.html
That is for the 1 series - is the Z4 considered a 1 or 3 or what? The 3 series that you cut the dash for is this:
https://avinusa.com/10-25-bmw-3-series-e90-e91-e92-e93-android-multimedia-navigation-system.html
Reactions: fmorelli
3,642
Prime Day sucked me in. I ordered an Amazon Fire 8 HD ... but the closer was the Show Mode dock - very clean USB micro connection ... and USB wire out the back. I'm hoping to mount the Fire 8 HD and Show Mode dock in a fairly clean install. $80 total on Prime Day for both.
3,642
I got the 8 and show doc ... think its too big. I'll have to look at something else. Field of dreams ... and besides, too much stuff is half broken right now ... going backwards not forwards ...
