Clutch/flywheel has roughly 5000 miles on it. This setup is for an 8 bolt N54 car. I bought it from a guy who ran it on his car but it started to slip when he turned up the boost on his single turbo car. (Was told he was around 700whp) he pulled it and went with a twin disk. The clutch and flywheel are in great shape, the pressure plate has some wear but should probably be machined down to make it perfect. This is the OEM style stage 3+ spec clutch.
Reason for selling: my car is actually a 6-bolt so I cannot use this and I have sourced a completely different twin disk clutch setup more in line with my future goals.
Keep in mind this is a USED clutch, and there are no returns on this setup. What you see is what you get.
Spec Stage 3+ Clutch/Pressure Plate: $350 picked up, $380 shipped
M Factory 8 Bolt Flywheel: $350 Picked up, $380 Shipped
Together: $650 Picked up, $700 shipped
Located in Norwalk, CT
Pictures can be found in this link:
https://photos.google.com/share/AF1...?key=UDZkeTNBUUJ2eElHLS1NbG5zbU1SZkgyRXhUT1BR
