Technical Spark plug indexing
Spark plug gap facing what direction?
  • Intake valves
    Votes: 4 80.0%
  • Exhaust valves
    Votes: 1 20.0%
  • Total voters
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Disclaimer: this thread not meant for debates on whether there are any hp gains from spark plug indexing
When it comes to spark plug indexing I've heard 2 different "correct" ways to do it. Gap facing intake, and gap facing exhaust.
Traditionally, domestic guys and NASCAR race teams have indexed with gap toward intake valves. Justification was to promote equal flame front travel on both sides of the plug, more complete combustion, more power.
On N5x Enthusiasts I've heard the opposite, index with gap facing toward exhaust valve. Justification was to promote spark plug cooling under load and protect against spark blow out by putting the ground strap between the intake and electrode tip.
I'm about to install new spark plugs and will be indexing them. 6266, E85, high boost, port injection, NGK 2 step colder plugs, and R8 coils. Which way should I index my plugs and why?
Reactions: JimboFresh206
1,067
I only recently learned this was a thing. My biggest concern is about the change in height of the plug.
The plug won't extend as far into the chamber and that seems like a problem to me.
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
I think that might become an issue if you stack 5+ indexing washers, they're pretty thin (0.030", 0.050", and 0.060").
Heat range is unaffected since that's determined by the contact between the ceramic and metal thread collar of the plug.
JimboFresh206
289
152
335/635/535/533/633
Wouldn't towards the Intake valves be for a port injected car?
so on DI... towards the injector? (which is still towards the intake valves)
Erichale77
827
447
Clearwater, FL
07 E92 coupe
I would index plugs to face injectors. Perhaps slightly towards exhaust valves if blowout is a concern. If I'm not mistaken, our DI injectors spray downward and not towards either valves so as long as plug gap faces center you should achieve a complete cylinder burn. IMHO
Reactions: veer90
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
per BMW documentation on the N54, injector spray cone is specifically designed to not wet the spark plug under normal operating conditions.
3,642
The plug is an M14 diameter with a 1.25mm thread pitch: that's about 0.050" in advance or retard per complete turn. If I was indexing the plugs with multiple spacers, I would want washers that gave me whatever increment of control I'd want over a 360 degrees - 0° to 360°, one full rotation, is 0.000" to 0.050" spacing. So if you want 45° increments, for example, the spacers want to be about 0.008". I've not done it before, but I would imagine putting a mark on the plug and torquing it in place, noting its "o'clock" orientation, calculating the negative rotation angle, spacer thickness respective to the delta per, and index with appropriate washers. In my case, given I have a thickness sander, I'd just fab the exact washer thickness I need for each plug.
All that said, and back to your original numbers, common indexing kits (e.g. Moroso) have huge index values (like you suggested). Why is that?
JimboFresh206
289
152
335/635/535/533/633
Does it possibly have to do with this originally coming from 2 valve heads, with the plug entering almost horizontally?
The v8 hemisherpical and flat heads only have 2 big valves to clock the plug between, opposed to our 4, with the plug basically in the center of the head.
On my 442 I would index them, but never cared about being "exact" given the size and location of the valves.
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Update: installed spark plugs this weekend. NGK 97506 @ 0.025" gap. Indexed with gap facing toward intake.
Car idles a lot smoother, sounds smoother while cruising, and feels very strong on pulls. No misfires, no timing pulls. Will turn up the boost as weather permits.
Reactions: Twinz and fmorelli
san40
10
2008 E90 N54 6MT 335i
Took me a while to index NGK-97506 with hard to remove copper washers. Ended up bending them a bit to remove and then flattening in a vice. Once removed, they could be screwed on and off. Sanded washers to index "up" ( with spark opening towards intake ports and injectors).
Also found this while researching indexing: https://mbworld.org/forums/w212-amg/869608-diy-spark-plug-indexing-video.html - same ideas apply to AMGs, apparently.
