So close to running 10s on Stock Turbos - N54
Silent11
93
30
2007 Bmw 335i
A bit of weight reduction, HEAVY "Skinnies" (23.4lbs), and some good ol' maintenance ( walnut blast, New trans fluid with 2008 TCU ) got me super close to finally running 10s on stock turbos. Sticky track helped a bunch with the 60 Foot . Crushed my previous PB of 11.46 all 4 runs
Also managed to run EXACT times back to back runs :)
Mikejones1208
146
113
Savannah, GA
2009 BMW 335i
Not bad man, with that trap your close to maxing out stock twins, need some more weight reduction now to get you over that hump!! Unless you can get your 60 ft. Down to a 1.5, but that all depends on what your rear end setup is and how your launching
Silent11
93
30
2007 Bmw 335i
There were no street tires allowed so track was nice and sticky. 1.68 1.67 1.64 were my 60 foots. Previously my best was 1.73 without the "skinnies". 2nd gear launch with MT et Street SS. Racing diffs LSD kit is helping as well. Rear seats and pass. seat were removed along with cowl and some trunk stuff. Ill try removing the sway bar and possibly rear seat belts next time i come out. Ran with almost half a tank so couple gallons less cant hurt. So close to 10s !!
Mikejones1208
146
113
Savannah, GA
2009 BMW 335i
I know people have done it already, ill see if i can dig up some old posts, but there has definitely been stock twin guys in the 10s before
Silent11
93
30
2007 Bmw 335i
I'd love to see the stock turbos get into the 10s.
What is your mod list?
Wedge tune E50 @ 22psi made 460whp / 530 wtq just last week
Downpipes, inlets, walbro 525, vrsf race 7.5 fmic
Racingdiffs LSD kit, 275/40/17 MT et Street SS on 17s ARC8s
xhp stage 3 v.3.0 stock settings for now
Weight reduction
Rear and passenger seats out, trunk cover, engine cowl, 23.4lbs Vision Skinnies 17x4.5 , S/R sportsman tires 18lbs
Planning to remove front Sway Bar, Rear seatbelts, switch to 5 series spares 17x4 only 17lbs compared to 23.4 skinnies what i have now. Maybe et front bias plys that are 12 lbs compares to S/R sportsman that are 18. Not sure now bias plys and drag radials mix ? Was looking at 21lbs braille battery but not sure if that will make my traction worse, but 30 lbs is a lot.
Any other weight savings you guys can think of ?
Reactions: NoGuru
rev210
171
73
335i - 08 Coupe .
Weight reduction
Great job!
Bias ply and radials dont mix , steering nightmares. Thats why they sell skinnies in both and also the drag tyres too. Bias ply are pretty horrific to drive on and they go with full slicks normally.
