Single Turbo Boostbox Tuning
chrisdfv
270
216
E90 335i
I've been deep into this topic recently and discovered that there's not much information out there so I wanted to create a place where people that self tune can have a discussion on the topic.
I'm using a boostbox V3 to tune my car, and have only began tuning at the moment. I enjoy the learning process and feel it's rewarding to drive around my car knowing how everything works together.
First topic of discussion
Using setpoint vs. RPM to dial in boost, or sticking with the traditional boost control logic the car operates on stock.
Other things I will be working on once I'm comfortable with my boost control is extending spool mode to 3.5K-4K RPM, adjusting Spool, and main table Vanos(on cobb vanos currently), spool fuel, and spool timing.
Not interested in playing with lean spool.
Log with No WGDC values or PID values. Signal to boostbox inverted(required for V3) xdf addresses can be acquired from Motiv to verified customers.
https://datazap.me/u/cd919/log-1517780355?log=1&data=3-4-5-7-8-23-29-31
Good subject, as I'm sure you know there is also a bit of difference between v1/2 and v3. I have the v3 on my car now but my tune has not been updated, which I'll need before I drive it around.
chrisdfv
270
216
E90 335i
The difference isn't big, but needless to say the results would be bad if you drove a V3 without the required bin changes.
Reactions: veer90
chrisdfv
270
216
E90 335i
And it appears the trick here is to get spooled without overboosting, seems this is part of the tuning art
Reactions: chrisdfv
all4bspinnin
178
98
135i TT
good thread. I use rpm x setpoint personally. The key with these is getting pid dialed in right. What did you do with your d factor? A common practice seems to be to cut the table in half on the stock turbo stuff however, I've had success with leaving it stock.
Reactions: Otto Bahn
chrisdfv
270
216
E90 335i
My D factor is cut in half, and then the top left is cut in half again. Haven't really had a chance to take some more logs and make further adjustment. Right now it seems I need to catch my spool sooner.
https://datazap.me/u/cd919/log-1518095329?log=1&data=3-8-23-29-31
Here's two more logs. I've adjusted my base table to this.
all4bspinnin
178
98
135i TT
we're running nearly identical d factor. I left my P factor table values below 2500 in there but the overall correction values are similar as well.
I would double check your timing at 4500. It looks like the car has learned a lower value for that rpm possibly the result of repeated correction.
Im also intrigued by your illuminati numbered rpm breakpoints on your rpm in your rpm x sp table lol
chrisdfv
270
216
E90 335i
I’ll check my timing table when I get a chance.
Lol they’re just evenly spaced!
Updated rpm x sp table some more.
Not sure why pid is timing out. Possibly because my requested load is set so far out of the way? Also having poor post shift timing.
https://datazap.me/u/cd919/log-1518220059?log=0&data=3-23
all4bspinnin
178
98
135i TT
in your situation, I would lower the load request
the post shift timing pisses me off. its a common problem and im pretty sure theres a burst knock table or something that mhd hasnt found or released. boost spikes seem to cause it as well
chrisdfv
270
216
E90 335i
I had it set so far out of the because I found to load overshoot during shifts would give me terrible timing post shift.
Currently have stock L2T with different Y-axis scaling, and modified torque eff fuel.
chrisdfv
270
216
E90 335i
Started incorporating spool mode tables into my tune. Extended spool mode exit to 4K, and re scaled the rpm axis on the vanos, afr, timing tables.
Spool is increased by about 500 rpm.(0-20PSI)
The issue I'm running into with this is my rail pressure crashes on tip in, trims go max positive, and afr goes lean...
Log shows that the dme stayed in spool mode even after surpassing boost target. Shouldn't it exit spool mode as boost approaches target? Could this be due to my boost request offset table set to 80 in every cell?
Logs:
NO Spool mode
https://datazap.me/u/cd919/log-1519056142?log=0&data=3-23
with spool mode
https://datazap.me/u/cd919/log-1519009103?log=0&data=3-5-7-14-16-17-23-24-25
Reactions: 335is02
chrisdfv
270
216
E90 335i
Well, after many logs and revisions yesterday. I think I got my rail pressure crash under control.
I ended up using the BRO table to slow down boost target rise. Using 90% values everywhere. The overall target was lower, so I also had to raise load request to get my target where I want it (~20psi). Also blended my spool vanos, to match my main table upon exit, and it seemed to smooth things out. Car felt good on this log.
https://datazap.me/u/cd919/log-1519132155-0?log=0&data=3-7-8-9-10-11-12-23-26-27
Sbrach
224
175
N55 DCT E82
I haven’t done much experimenting with spool mode, I’ve pretty much just left it alone on stock turbo, but I don’t think it ends at target boost and your logs seem to support that assumption.
It looks like your issue was just overboosting which you have resolved with BRO and load request.
Do you think you need to run spool mode out to 4K even though you are spooled by 3500?
chrisdfv
270
216
E90 335i
That's a fair point. I could set spool mode exit to around 3.5k, but it seems to be running good now. Now the battle to sort out post shifting timing corrections begins. I notice it's most prevalent when load actual overshoots load request during the shift boost spike. I can feel the bog while timing recovers. I also notice it's better when I shift at 6.7k vs 7k.
https://datazap.me/u/cd919/log-1519222899?log=0&data=3-8-9-10-11-12-23-27
all4bspinnin
178
98
135i TT
I think anywhere from 3500 to 4000 on a single is a good range for spool mode. The log you posted earlier looked pretty good. The boost spike always causes timing drops... that's for sure. RSL mentioned a while back that he tries to keep load as close to the same value before and after shift so there isn't a drastic change. I didn't have much success with it on stock turbos. I did however have some success recently by adjusting some of the torque tables to prevent post shift drops. The idea is you want the transmission to shift as smooth as possible.
chrisdfv
270
216
E90 335i
I will try to take some more logs with shifts, and evaluate if I need to dig into the L2T tables.
I played around with vanos last night. Same values in my spool table(68/84). More overlap in general in my main table.
Spool appears to be "slower" in log, but rail pressure is lower and trims are higher through the whole log with the vanos changes. Boost is lower with the same wgdc, so my theory is I'm consuming more air, and fuel. Gainz?
Cobb Vanos
https://datazap.me/u/cd919/log-1519699711?log=1&data=3-6-22
Modified Vanos
https://datazap.me/u/cd919/log-1519699764?log=1&data=3-6-22
I don't trust VD all that much, but the green is new Vanos, red is Cobb.
