Service port on head for crank case vent
Asbjorn
856
606
European, based in China
Z4 N54 DCT
Relevant quote from Martymil in case you didnt know
Stock is 17 mbar or 0.5 inhg or 1.2 cmhg
I personally can't run anymore than 2 inhg without one of the seals whistling like crazy
I see it this way as long as you run anything higher than stock without seals whistling you will be ok.
Omar@VaderSolutions
Premium Vendor
Oct 19, 2016
533
408
NY & AZ
vadersolution.com
N54 135i & N54 335i
if your car needs this fitting i feel like there are other issues you need to address, on my older breather kits i had a lot of people run a regular m18x1.5 to 10an fitting without any issues at all for years... the trick for them was to have the 90* angled upwards towards the hood. but even then some people would do that and still experience oil going through the lines and into the cans. might want to look into plugging your head ports, or getting a new valve cover. i know you have the pvc delete fitting that plugs the head ports for you but with a valve cover thats internally cracked it wont do you anygood.
I have ports plugged and don't want to use a 90. I've never even tested it with that port, I did this as a precaution because it seems most people need a 90 and I wanted to avoid that for cosmetic reasons.
I meant to say, I don't want a 90* fitting pointing upward to use gravity to avoid the excess oil issue. This lets me angle it downward and the entire occ assembly and hosing can remain unseen.
AshwinLB
39
26
Toronto, Canada
2008 135i 6MT "Narrowbody 1M"
As an update, I bought 10 fittings as an experiment and have sold the other 9 to people wanting to test this with me.
My theory: The oil is being slung up onto the vc from the cams and it runs down the side of the VC right into this hole:
You can see that area appears washed clean from oil. The custom fittings actually protrude two inches into the hole so the oil will get caught on the threads and drip down instead of going into the hole.
Here is the drawing for anyone who wants to copy it. I sent a request out to several random companies online and this one from England of all places was the smoothest to deal with so I proceeded to use them despite the distance. My contact was Andy AT customfittings.com and the description is:
1 – 7/8”-14 JIC x M18 x 1.5(Flat Faced)WITH A 2”LENGTH OF THREAD MALE/MALE
HEX ADAPTOR AND THE METRIC END WITH A 7/16”BORE
Keep in mind, I had a larger than normal drill used for the M18 side, I choose 7/16 but after receiving it I can tell there is enough margin to do a 31/64" straight through.
The shoulder is also round just like the head, it is a perfect fit:
I'll hopefully get a chance to test it in the coming weeks.
Did you ever end up installing this?
