I've been trying to find a 'pretty' way to vent the crank case from the front since I have a single turbo and the intake pipe is up there. I know several people have used the chain guide service port but have experienced excess oil being drawn out. I know the VTT valve cover has a port for it on top but I figure I'd like to see the hose come off the side of the engine instead as it would be a bit more stealth.
Here is the area in question:
I know people have suggested to use a 90* fitting pointed up, but this wouldn't accommodate the stealth factor. I have thought about having a splash shield and even went as far as buying some air 'mufflers' off mcmaster however they are simply too large for the space given. I'm convinced that a splash shield of some kind would be necessary in order to maintain a decent level of air flow, as opposed to a restrictive stone filter for example.
I did find this on ebay:
It is meant to be used on on the flat spot of a valve cover, but perhaps if the bottom was shaped more like the head trough in the above photos, then maybe something like this would work. If you had an AN fitting with LONG M18 1.5 threds, you could screw into it and the shape of the bottom would keep it in place due to the rounded shape.
More ideas:
Anyone else have ideas, thoughts? I'm still unsure where the oil is coming from exactly (from the cam spin, drip down from the valve cover, etc). Looking at the oil stains, it appears to be cleaner where the oil runs down from the VC.
More ideas:
