RHD Long Runner Single Turbo
Brule
392
463
335i 2007 6spd manual
Heres a manifold I'm making.
Always wanted a long runner manifold so I'm making one.
Few photos of the progress.
2,267
814
You’re one mad mofo!
You’re improving your fab skills everytime
If you can do these for a decent price you’ll be a busy boy
Coupes66
BMW 335i N54
You would have to be Houdini to get the lower nuts onto the manifold head studs Brule.
rac
341
205
135i ST
same here for my long runner. looks impossible but the trick for mine is to have some nuts made up to the studs and then make them up at the same time as the others, and one nut i modified to be shorter. and i'd rather slam my dk in a door than get my water pipe out again which is what i did recently...
Brule
392
463
Runner 3 bottom will require stud to be cut to get nut on it. Probably a half hour nut tightening session on that one.
The rest are alot easier then the other 2 manifolds due to the runner size and they all come off the head heaps which allows room.👍🏻
Brule
392
463
I
i hope you get some results for effort out of it!
Good result = Sound improves.
If it doesnt make top end power Ill match it with a precision 5862 or similar g30 Garrett to make a good spooling drift or street setup.
