RESULTS - Fab Factory Billet Intake Manifold vs. Stock IM
A4RingedONE8T
82
134
Thank you to @martymil for providing us our first back to back results, stock vs our N54 Port Injection Billet Intake Manifold on a 1M!
First dyno is a direct swap of intake manifolds, absolutely NO changes except for intake manifolds
And with a few flash tweaks/minor retune
All comments/discussion welcomed!
-Shawn-
A4RingedONE8T
82
134
Logs
Before - stock IM
After - FF IM, no tuning changes, only manifold/chargepipe
Tuned - basic reflash with FF IM
  • 1M Swap - Before.csv
  • 1M Swap - After.csv
  • 1M - tuned.csv
A4RingedONE8T
82
134
Less power??
All the other intake manifolds :tearsofjoy:
Red lines on both graphs, before with stock IM. Blue lines after FF manifold install, first graph no tuning changes, second graph with tuning, no boost change. HP and torque both up. Look at the plots and the area between the red and the blue, that's your gain. I believe my manifold is the only one actually gaining anything on it's own. Roughly 20hp on a 400hp car. Add more power/boost and see what happens, for example, Tony's N54 record 910wtq through my intake manifold.
-Shawn-
Mar 14, 2017
418
346
Minot, ND
2010 135i
Nice improvements. I'm sure ported intake runners and larger turbos make up for that drop at the very top. For stock turbos this shows a significant increase in air flow.
Twisted Tuning
Oct 25, 2016
982
915
New York
www.twistedtuning.com
N54 and N55 Cars
Nice gains under the curve. @A4RingedONE8T don't worry about people saying "less power" was made. Most people only focus on peak power and don't realize that the areas under the curve Are just as, if not more important than the peak power
This a stock turbo(s) car?
brocke
29
7
1m
Its running rb classics
Our aussie dynos read a lot lower so around 400+rwk on american dynos
The car ran 11.8s@121 mph on 98ron pump gas or your equivalent is 95ron at the local dragway on a stock manifold and before the coils where done, should be little faster now
JuniorB
343
112
Rhode Island
07 e60
How is the new intake being aluminium,holding the heat? Do you feel the air intake would be hotter on the intake? It's nice tho,over the design
Erichale77
827
447
Clearwater, FL
07 E92 coupe
Not like that at all. The FabFactory mani is in a league of its own. Every part of its construction is specifically designed and not just thrown together.
brocke
29
7
1m
That doesnt look anything like it.
The alibaba one would make an good ornamental doorstop
