I had (at least) one of my aftermarket turbos fail, which was fitted on March 2017.
So now I've sourced some replacements but I'm wondering what other bits need replacing? Can you guys help me out with a list?
So far I think I will change the turbo oil feed and oil return lines (in case of debris and to have new ones).
I will replace the coolant lines
I have the gaskets for the turbos.
I will get some vacuum hose
Is it a good idea to replace the copper nuts and the studs?
So basically get together a turbo install kit like found on ecstuning I guess.
Will have coolant to refill after disconnecting the water pump. Necessary bits for re-attaching the water pump
and the oil for an oil change, plus filter.
I think it's also a good time to change the O2 sensors. Do I do just pre-cat or pre and post cat? I have catless down pipes.
What about the oil pan gasket as well, for the sump?
Thanks
Thanks
