Hi all.
My name is Justin from South Africa.
I'm having a frustrating issue which I cannot get to the bottom of. Seeing as you have a great DCT subforum here. And very knowledgeable members. I'm coming here for some much needed help.
The issue:
A few weeks ago. I did Stage2 turbos. Chinese Brand TD04L-16T.
After fitting car ran well and I popped a boost pip from IC to CP. Had it put back on and my mechanic apparantly did a DCT Gearbox reset (only found this out long after this) via Protool or whichever tool he used.
Got the car back and for about a week or two the car ran great and I was driving it well without issue.
One day I had WOT and the car bucked and lost power like a I popped the boost pipe again.
I checked everything and no boost pipe issue. Plus I still had full boost when I got onto the throttle again.
Everytime I go WOT now. Especially to log, I get the "throttle closure" issue.
I've now narrowed it down that it seems to happen when I exceed 5000 rpm. And mainly in 3rd gear. I havent done a proper log through 4th gear yet. But will test this when I have enough road.
The issue feels like the throttle closes. In my log I can see it, my throttle value dips and then all goes to shit.
Things I've done to troubleshoot:
Removed BMS BEF - still present
Removed JB4 - still present
Replaced Spark Plugs (oil in well 3)
Replaced new BMW Valve Cover at BMW
Replaced new BMW DCT Oilpan at BMW
Done DCT clutch Relearn Procedure at BMW
Installed a softer spring into my Tial BOV
Replaced Throttle Body
Flashed DCT with WinKFP to 8609092 ZSUB
Replaced new Vacuum Lines
My WGDC values in JB4 max out at 40%. So no boost leaks.
My fuel trims look good.
My AFR look good
Timing looks good
All the above is Map1 and I have a BMS Pump BEF loaded.
All firmware and BEF is the latest and all up to date.
I'm considering possibly changing either HPFP or LPFP. But my values are in the required range from N54Tech. So I dont think my issue is there.
I met with a BMW "DCT Specialist" at BMW dealer. And we went for a drive. He said that he feels the Clutches are out of sync and its causing the second clutch set from trying to come in while the first clutch is still operating. And says this is a software issue. But I'm not convinced.
My current mods:
JB4
BMS Pump BEF
Stage 2 TD04L-16T turbos
2inch Inlets
6" Intercooler
Charge Pipe w/Tial BOV
WMI with CM10 Nozzle
Upgraded Vac Lines (Platinum Cured)
I know there is Torque limits for the DCT box. But I highly doubt I am reaching this. Specifically since the issue happens when JB4 and BEF is removed also.
Could I be experiencing an actual DCT Gearbox hardware fault?
I'm considering updating the PUMP.bin I'm using to set the "Disable Tq Reduction by Ign" value and set the parameter to "00" as apparantly this is the recommended value for DCT.
I know I can get a custom flash. But dont want to spend for a custom flash yet till I can confirm this issue is not software related?
Please may I have your thoughts and advice if any.
If any other ideas on the BIN tables. There are other tables in the same XDF for the above "reduction by Ign" value in terms of Disable tq Reduction Path..."
Should these be set to the 00 value same as the OEM Software bin values?
Thank you in advance.
I'm really at my Wits end and have no idea where else to turn.
Justin.
The issue:
My AFR look good
Timing looks good
My current mods:
JB4
BMS Pump BEF
2inch Inlets
6" Intercooler
Justin.
