SOLVED pls help: Mixture control faults
johnnyd40
9
So i've been trying to track down exactly why my 335 has been setting lean mixture faults, mostly on bank 1 but sometimes will see bank 2 pop up as well
Car is an 08' N54 w/130k miles, mods are as follows, chargepipe, downpipe, relocated inlets, 3.5tmap, fuel-it stage 2 pump, VRSF intercooler, MHD stg2+ tune. Within the last 6 months the car has gotten new HPFP & low pressure sensor, EKPS, and I installed a new FPR/siphon jet when the fuel-it pump was installed. Also had an index 11 injector that was slowly leaking down so i replaced them all with index 12s (they were used)
So far I have smoke tested the intake tract, crank case, and exhaust with no signs of an air leak. I filled up with Shell 93 and put in a bottle of techron for good measure, cleared adaptations and approx 75 miles later it set bank 1 lean mixture fault again. I've switched to a different version of the MHD software and no difference. Car runs well. Im leaning towards oxygen sensors giving bad info, but cant be sure. I've graphed a log and will post it (not even sure I did that correctly)
Any insight would be greatly appreciated, sorry for the novel.
johnnyd40
9
johnnyd40
9
For anyone who is having the same issue and having trouble- the (used) index 12 injectors I had installed were tired, I swapped out bank 1 injectors for some of my index 11s, adapted them and cleared faults, hundreds of miles later and bank1 mixture faults are gone. I will be sending the 12s out to injector-rehab to have them cleaned and tested.
Z4Dude
16
GA
M340i and E89 Z4
I'm having some of the same issues..... I have traced leaks, replaced vac lines, replaced Valve cover and gasket, intake gaskets, new CCV, smoke and pressure tested everything and it all tests good. Car runs great until I get ion it and into boost then it quickly goes lean on Bank 2 and then creates misfire codes for Bank 2. I'm running index 12 and checked for leakage ,but they are testing good as well. TI was pointing toward the o2 sensors as well but if you drive normally everything works fine.
I'm currently leaning towards my HPFP.... I have watched a few rebuild videos where you can measure the depth of the diaphragm from the end of the pump and mine seems like it is far past a recommended limit, but not sure how accurate that recommendation is. My logs show some rail pressure dives when the codes pop, but it's hard to tell if it's a symptom or a cause.
It sucks not being able to use all of the mods and power.
