Parts required to upgrade the twins with inlets
Mzfhartge
63
18
Somerville, Ma
07 bmw 335i
Hello everyone,
Need help to find out what exactly i need to upgrade my twins with the inlets? 2007 bmw 335i, it is my daily drive but i am aiming 600tq so i dont mind having a harsh clutch.
1-Do i need to get the diesel coolant resevoir or i can use mine and get the bracket from precision and the plug and play harness?
2- Also what about the power steering reservoir? Do i need to get the bracket for it too?
3- Rb high flow oil drain, i was told i needed that.
4- New clutch/flywheel to handle the power. Need sugestion please as i am leaning towards spec stage 3+ and mfactory smfw but i heard it only last 30k so i might need something little better and its rated to 580 tq if i am not mistaken.
5- Upgrade fuel to stage 3 dual pump bucktless. I already have stage 2 so this should be easy. Bmp sells the stage 3 and i will get that from Steve.
6- Port injection. I would like to get the manifold thas the port injection built into it. There was a group buy i saw somewhere where you can get the manifold with the bmp injectors 750cc.
7- vrsf 7.5” hd race intercooler.
I should add that the car is fbo already on stock twins with bl coils.
If you have any of the parts i need please pm or email me [email protected].
Mzfhartge
63
18
Somerville, Ma
07 bmw 335i
Ok quick update.
It turned out that my kit had the brackets needed for coolant reservoir and harness so item 1 and 2 is not needed anymore.
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
don't forget the turbo installation kit, $250ish depending where you buy.
how do you connect the relocated coolant tank to the water pump? do relocated inlets come with a long coolant hose or how is it done?
Mzfhartge
63
18
Somerville, Ma
07 bmw 335i
The kit i bought had the turbo installation with it that included the brackets too and the hoses needed.
