Not able to reach boost target
Mon54ster
18
Hello guys! I'm trying to find out why I cant reach boost target. I have no codes whatsoever and the car is FBO. It is a z4 sdrive35i DCT trans. Upgraded turbos, inlets, 7.5fmic, ER Chargepipe with turbosmart bov, downpipes, flex fuel kit, PR coils. No wastegate rattle at all. Only thing I haven't done is tapping the manifold for the bov vacum line. Thanks in advance!
Mon54ster
18
Thanks! Car made 400whp and 396ft.lbs on 14psi and E30. But I need to find where the leak is. I guess boost mean is boost detected at the CP right?
Also see the stft's how they follow real close and yours are spaced out, not a big deal but it will get worse.
You will need to change 1 injector at a time on bank 1 and test each time to find out which one is leaking.
Reactions: Mon54ster
Mon54ster
18
Would the burble tune on mhd cause this issue? Its currently on its max setting for 1 second. Also is there any way to test boost solenoids? What can you tell from mi wg parameters? Turbos seem to be holding boost pretty well. No rattle at all.
Mon54ster
18
Also these datalogs were on the base map, I have received the revision and will be datalogging on friday. Sadly my tuner is a little bit lacking on providing information on what he sees on the datalogs :( would like a little more personalized help from him.
