Were just jealous of the B58 that's alli see that, but it’s all good. Everyone has lives, busy times ig
B58 or N54 really they self destruct at the same tq level. And post some logs, someone will be able to help.I love the platform, we’re all in it for the same reasons I’d think though. What’s a B58 if it leans out.
And what TQ is that would you say ? At what RPM ?B58 or N54 really they self destruct at the same tq level. And post some logs, someone will be able to help.
Anything above 550wtq below 5k rpm . I've seen a few doc race 240i's blow in the 710whp range.And what TQ is that would you say ? At what RPM ?
I appreciate the time looking at it, I have a TU pump incoming Monday. A little piece of mind running ethanol blends. After that, MHD’s CAN FlexFuel kit when it gets released For b58. I’m not really trying to go over 500-550hp.Everything looks good, I'm assuming the lean part in the beginning is the B58 version of spool mode. I reviewed a few other logs and they all appear to do the same.
Sounds like a solid game plan, Possibily the pure 800 is the turbo for you, should be able to do 550 on pump gas and ethanol.I appreciate the time looking at it, I have a TU pump incoming Monday. A little piece of mind running ethanol blends. After that, MHD’s CAN FlexFuel kit when it gets released For b58. I’m not really trying to go over 500-550hp.
I’ll look into that, I’m actually curious as to how much the TU pump can handle. I haven’t really found concrete numbers.Sounds like a solid game plan, Possibily the pure 800 is the turbo for you, should be able to do 550 on pump gas and ethanol.
Just go PI with reflexI’ll look into that, I’m actually curious as to how much the TU pump can handle. I haven’t really found concrete numbers.
Ohh, yeah I see that. That looks like it was during a shift. I wonder if that’s typical during shifts.You had a lean spike which is concerning but may be an anomaly.
Ahh I didn’t notice the shift part. Should be all good then.Ohh, yeah I see that. That looks like it was during a shift. I wonder if that’s typical during shifts.
