Thanks ! My maintenance is all up to date. The car was maintained regularly at a BMW dealer from day one. Question about your charge pipe. I see people have issues fitting it because of the ps reservoir in place and having to relocate it. Some rub on the ps hoses as well. Im thinking i want to get TS bov too since the TS plumbback on my 335i is so nice and quiet. Do you have the raceport GenV ?That is a beautiful car.
I have an 08 e60 535i msport....or just sport. I pulled the build specs and it says msport suspension. But it had paddle shift delete. Not sure why....odd build I guess.
For the fbo I'm running vrsf catless dp's, vrsf 7.5 stepped race intercooler, mmp full silicon inlets and outlet, mmp charge pipe, turbosmart bov, ngk coils, oe Bosch plugs. I'm using stage 2+ e30 mhd tune and xHP stage 3 tune.
Maintenence I performed. New oil cooler, new water pump, new hoses, new radiator, new condenser, new ac compressor, new pulleys and belt, new valve cover, new throttle body and I rebuilt the valve body on the transmission.
She runs beautifully.
You should have no problems doing a complete fbo on yours. Make sure you cover any maintenance you may need for your car to be able to have no issues with the extra ponies.
I love you have the manual trans.
as i said i have a 335i that runs low 11 sec. so i know all about the n54 maintenanceOh.... and I have the Vader solutions vacuum adapter to run to the bov. I also have the 3.5bar sensor on the intake.
as i said i have a 335i that runs low 11 sec. so i know all about the n54 maintenanceglad to hear you havent had any issues with the charge pipe. I dont think ill go crazy with this one since its so clean and well maintained, i got my 335i if i want to go fast. The 535xi will just get a couple mods and a tune. Will try to mount style 230s this week hopefully to change up the look a bit. Not digging the 17s
