Well it has been a long time coming, but we are proud to present the new intake manifold N55/S55/N54 community. The manifolds will be available in a few different configurations based on customer needs and wants. The features of the new manifold are listed below:
*Topside injector mounting (ease of service if needed and just plain looks cool!)
*Injectors are placed on optimal path towards the valves
*Manifold has 1/8" taps on the bottom side for port injected meth
*With basic fueling kit you get PTFE smooth bore corrugated fuel line with crimped AN fittings
*55lb/hr injectors are standard, but are also upgradeable to 72lb/hr or 100lb/hr injectors
*factory and most aftermarket intakes fit perfectly
*Fuel rail supports -6an ORB fittings on either end(standard config is dead end rail)
*Phenolic spacer is included as standard with manifold purchase
*Injector plugs available for those wanting to use the manifold for port injected meth
*2ea 1/4" NPT taps front side for sensors etc...
*3ea 1/8"NPT taps front side for sensors etc...
*High Gloss black powder coat is standard other colors available upon special request
*12ea OE gaskets included with the kit
*6ea extended length studs with hex head for easy install
*3pcs Standoffs for airbox
*Superior design flow path from stock
*3/16" Barb to 1/8npt adapter and 1/4" barb to 1/8" npt adapter included
*Each manifold is CNC machined after being cast to remove any excess material and weight involved in the casting process
*All manifold are cast and machined in the USA
*We control all aspects of the machining process in our in house CNC facility
We are just starting to ship the production manifolds so if you are interested please contact us.
