*** Updated build sheet 2019-10-31 ***
OK I lied.....it's never been my daily but I haven't driven it much in the past 3 years so decided to turn it into a dedicated track car. I needed a hobby anyway lol.
Background
Bought the car in 2012 and went full bolt ons over the next few years. Last year is when I decided to take it the next step further and go single turbo. Now at this point I had no intention on this being a dedicated drag car. It was meant to see a track day every now and then but still beat the piss out of it on the way to cars and coffee or something and not care if it broke. Well, started the single turbo conversion then work got crazy so never finished it and just sat on the lift for 6 months. Fast forward to the present. Had a phone call with a shop that does quite a bit of Time Attack/NASA, etc builds regarding my intentions with the car. We started laying out a plan and well, here I am. I drop the car off in about a month and it'll probably be there for a little over a month getting some things done that I either don't want to do or can't do. Maiden voyage is SCT Joliet, IL in May but we'll see. Scope creep is already happening with this build and I haven't even dropped the car off lol. He's currently working on a badass Time Attack E90 right now. His mentality is either do it right the first time or don't do it at all, and I accept that. Google "WTCC Widebody Time Attack E90" to see what I mean.
Goal for the car is to be a dedicated drag car and take the 6MT as far as possible. MHD for now and possibly standalone in the future. Built motor at some point in the future. Goal weight without me in it is 2700 lbs with the cage. I don't think it's possible with my current weight reduction so I may need to gut the doors, lexan windows, and a few other clever tricks. I think with the right setup 9's is definitely possible, but we'll find out I guess. It's been said this isn't at all possible in a 6MT but I'm going to take a crack at it. I like a good challenge. Will be attending plenty of SCT's this year so we'll see.
You'll probably see a lot more updates on my IG account, but I'll try to keep this thread updated as much as I can.
Mod List
Here's the major stuff worth noting. Doesn't include all the maintenance items I replaced. If I knew when I started the ST conversion that this would turn into a dedicated drag car I would have gone another route with a few items.
Engine/Drivetrain
DocRace 6466
MFactory lightweight flywheel
MFactory 3.08 Helical LSD
Turner Motorsport solid diff mounts
Turner Motorsport solid engine mounts
Turner Motorsport solid transmission mounts
Turner Motorsport solid subframe mounts
Spec stage 3+ clutch
Custom hood exhaust
PSP 900 intercooler
Custom chargepipe
Turbosmart BOV
Precision Raceworks coils
Precision Raceworks stage 3+ LPFP TBD
Helix HPFP overdrive
Injector Dynamics fuel filter with pressure/temp sensor
MHD TBD
VTT crank bolt capture
HVAC delete
Power steering delete
Rhodes Race 3 gal fuel cell
Suspension/Brakes/Wheels
Suspension info coming when I figure out what I want. Likely switch to full spherical bearings and custom coilover setup with custom valving
ASD hydraulic e-brake
ABS delete
Tilton 800 Series pedal box and master cylinders
Turner Motorsport wheel studs
17x8.5 ET40 OZ Alleggerita
Weld S77 17x5 2.2 inch back space
Hoosier 28x10x17 bias ply
Hoosier 27.5x4.5x17 bias ply front runners
AR Design line lock
Exterior
Headlight delete
Aerocatch hood pins
Pinch welds removed in front fenders to clear Hoosier's
Interior
Fully gutted
10 point chromoly roll cage by e-Fab Motorsports
Parachute handle
VAC seat mounts
Sparco steering wheel
Rennline quick release
OMP steering wheel hub adapter
Kirkey series 55 aluminum seat with cover
G-Force camlock 6 point harness
Hard Motorsport sunroof delete
Custom aluminum dash by e-Fab Motorsports
Rear firewall by e-Fab Motorsports
Pic before I started the ST conversion
Bought a car lift and installed it myself just for this build. Hell to the naw was I going to do this on the ground.
Sitting pretty. Unfortunately with stripping out the interior my garage doesn't look near this nice anymore
. I just moved into this house 3 weeks prior.
Came home from work and the DocRace kit was sitting patiently for me. UPS was suppose to leave it in the garage....I was so pissed.
All of the parts when I started the build. Things escalated quickly after this.....
Nom nom nom nom nom. I've drank lots and lots of brewskies working on this build lol.
How she looked as of summer 2018. Honestly, if I new I was going to go dedicated drag car I wouldn't have gone with the DocRace kit. I would have done something custom. For the price of the kit I expected fitment to be a little bit better. The turbo was resting on the shock tower even with new OEM engine mounts. Had to order Turner Motorsports solid mounts which actually raised the engine a few mm. I would have tucked the turbo down in the headlight.
Picked up some bias ply front and rears. Waiting on my Weld fronts. It's a 6 week lead time and it's been 6 weeks so should be any day now.
MFactory LSD. I really ought to do the 8.8 conversion. I'm expecting to snap the stock axles at my first outing since I'll have bias ply's and a suspension setup for drag racing. Also need to do more research matching gear ratio to the engine. I just went with the OEM 3.08. NOTE: Trans mounts are with old poly mounts. Went solid bcracecar.
This is when things really started to escalate after my phone call with the shop doing the roll cage
HVAC and windshield wiper motors deleted
Hard Motorsport sunroof delete panel. Looks like a quality piece. We'll see how it fits and if I can get the dang thing to seal....
That's it for now. More to come later.
Background
Mod List
Engine/Drivetrain
DocRace 6466
Custom hood exhaust
PSP 900 intercooler
Custom chargepipe
Turbosmart BOV
HVAC delete
ABS delete
AR Design line lock
Exterior
Headlight delete
Aerocatch hood pins
Interior
Fully gutted
Parachute handle
VAC seat mounts
