ok, at the risk of presenting as an idiot.....I received my boostbox with no instructions. So while I think I know how to install it, I don't wanna screw up and have to go back to jb4. Can anyone provide some direction??
I'll assume you're up and running with a jb4 and mac now? You should be able to just remove the connector that normally plugs into the stock vacuum solenoid, plug it into the boostbox cable, and plug the other end of the boost box into your mac solenoid. Then the plumbing for the mac solenoid should come with it, if not that is available online. Are you running one or two tial wastegates?
I don't know exactly how it is setup with a jb4 as I don't have one, so you'll need to wait for someone else on this one.
@[email protected]
I have one wg, and installed per your direction.
Yeah, wedge helped me out. Are lights supposed to flicker?So you got it hooked up okay?
Power light flashesYeah, wedge helped me out. Are lights supposed to flicker?
Mac solenoid light flickers constantly also?Power light flashes
What is this resistor in the picture? I got a boostbox and trying to find proper instructions.
The dummy plug is no longer needed anymore. I believe that was only on early Boost box versions or perhaps before the toggle to disable the code for not having the stock solenoids plugged was discovered.
There are two connectors on the BB. A male and female. one connects to the mac solenoid, and the other to where you'd normally connect your oem boost solenoid (you have two of them. leave one unplugged) and that's it and correct, it doesn't matter which one you plug the BB into.Thanks for the response.
So the 2nd plug from the harness just stays disconnected? Also, I suppose it doesn't matter which of the two the BB gets plugged into?
