Ad: MHD Wireless OBD2 Wifi Adapters!!!!
Twisted Tuning
Oct 25, 2016
982
915
www.twistedtuning.com
N54 and N55 Cars
Lose the Cable, go Wireless!!
Complete wireless connectivity. These are WiFi OBD2 adapters for MHD Flasher!!! Bringing full wireless datalogging and flashing via OBD2.
faster than our Blaze cable on E-series vehicles and even faster on F/G Series DMEs and Unparalleled range!!
Promo Video:
NOTE FOR F/G SERIES OWNERS: Black Wireless ENET OBD2 adapter is faster than this Orange version and have special coding specific to F/G series. Black ENET only compatible with F/G series vehicles!
PRICE: $69.00 plus shipping
PURCHASE LINKS:
E-Series: https://twistedtuning.com/products/mhd-wireless-obd2-adapter?_pos=1&_sid=fc0974ef0&_ss=r
F/G Series (And A90 Supra): https://twistedtuning.com/products/...g-series-pre-sale?_pos=2&_sid=fc0974ef0&_ss=r
Jewgo
65
28
1r
Has anyone found out if these turn off when the ignition is off? Or does it need to be unplugged?
Also, If you connect to the module, can you connect to a second wifi network or are you limited to one connection?
Thanks
Reactions: ShocknAwe
1,687
Thanks
Big +1. Can these be left plugged in to the OBD?
scrllock
267
153
2011 335xi
Speculation, but usually the OBD2 port provides power even with the car off, it might go into a low power mode, though. I believe leaving my bimmergeeks cable plugged in all the time gives me a power management code, but I've never had it kill the battery.
More interested in hearing if these can be used for xhp, protool, etc.
Twisted Tuning
Oct 25, 2016
982
915
N54 and N55 Cars
Thanks
The red LED stays on when left plugged in. But i can tell you that ive left it plugged in for days and a coupleweeks at a time with no issue. I guess it helps if you dont already have an aged battery, but i havent seen any codes on my N55 or B58 supra. I don't recall seeing any on my N54 either, but i cant remember for sure on the n54
Flashing with the MHD Wi-Fi is terrifying the first time but DAMN its fast.
With flashing this fast I find flex fuel unnecessary especially when you can do this whilst checking your tyres as I only use e85 maybe once or twice a year.
Less things to go wrong, simplicity is key.
1,923
662
Quick delivery, thank you @Twisted Tuning
On a side note, when I went to changed my mhd wifi password by visiting http://192.168.4.1/wifi/wifiAp.html
I noticed some settings like the cpu speed. Has anyone messed with those?
I posted earlier in the thread about it . It makes no difference probably just increases consumption . I assume it's their because this is not specific hardware so if it was used as a router or gateway it could be beneficial to have higher speed. In this application polling rate of the canbus is the limit though.
