MHD teases N54 Antilag with the stock DME
Asmo
43
37
Well, steering buttons option is a compromise for cars with no cruise control after all..
TiAgAu
139
56
08 335i
The radio / iDrive off is intentional, so that changing maps doesn't change your channel, etc. 2009+ iDrive should turn back on when you exit mapswitch mode. Regular radio you have to turn back manually
Fair enough. But as said audio doesn't return after exiting mapswitch mode. strange
TiAgAu
139
56
08 335i
iDrive CIC. Screen comes back after exiting switching. But audio is gone across the board via either usb /radio/bluetooth.
1,593
2,061
Anyone else run into this scenario w/ audio not returning? It worked properly for all the beta testers.
jakeg
80
31
FYI Guys,
The thor adapter doesnt work very well.
Ive tried multiple units, different phones etc. always fails to write to my dme.Same thing with most of my buddies. So now I have to go into winkfp and do the entire process again.
So if you dont have access to a winkfp computer, then dont use the adapters to flash your car.
1,593
2,061
The orange MHD adapter is much better suited, we had some firmware tweaks done to it. For longer writes you should have a quality battery charger hooked up. And on your phone, airplane mode and Bluetooth off, with just wifi on.
I flashed a DME over 100 times during development of all this and had no issues.
Reactions: ShocknAwe
jakeg
80
31
Yeah I had all of the above done. My buddy picked up an mhd flasher so i might snatch it off of him.
Is there anything else I can do to fix the failed to write besides the winkfp reflash?
My laptop was erased and I dont wanna spend a few hours reinstalling etc.
Sava666
173
36
How did you managed to trace Pre-turbo EGT? These are real figures?
1,593
2,061
Wierdly enough, my battery was at 12.4V. I kept light pressure on the mhd adapter and it worked. Now I have to wait for ken to get back so i can get the canbus map from him.
Hrm, check your pins in the OBD port, one of them might be getting pushed out a bit, causing a bad connection.
It is a modeled value, but it is the fastest to respond out of most of the DME's EGT models, so it is better than nothing.
Reactions: seb.apprenti
