just wondering...is it possible to log the raw value of the input?No need, he will be logging it via the DME.
I would sure hope not. Unless you are being facetious and referring to the intake manifold which would be obvious.In the intake under boost, you’ll see positive pressure.
I am saying that is you put the sensor in your manifold or charge pipe to measure vacuum under boost, you’re not going to see any. Maybe I misunderstood what you are planning on doing. If you’re trying to see max vacuum you’ll ever see in the cp/manifold, just let the car idle with the sensor plumbed. That’ll tell you how much vacuum it’ll apply to the crank case. Then measure what you’re Seeing in the crankcase via the oil cap.I would sure hope not. Unless you are being facetious and referring to the intake manifold which would be obvious.
In the latter case I have two or three 10AN ports coming from the crank case. Tell me how many I need to use given my ring condition. Ideally I'd like to use just one if possible if it wouldn't create unnecessary pressure.
Look at my photo, the sensor is on the intake pipe, not the charge pipe.
With a decent filter I expect zero or little vacuum reading here, but some people think it's more than this at boost levels so I'm checking.
I think maybe you should read the text I've typed because you're talking to nobody with that info.
I did not look at the photos and “intake pipe” evoked the cp in my head. So, as stated when I said, “maybe I misunderstood what you are saying,” I did in fact misunderstand what you were saying. Not sure what the snippy bit at the end is supposed to solve, but you do you.Look at my photo, the sensor is on the intake pipe, not the charge pipe.
Yep, the ECA Voltage parameter should do thatjust wondering...is it possible to log the raw value of the input?
It was a genuine comment. How you choose to take a comment that was positive and informative, if I had not misread/misunderstood your comment, is entirely up to you. The fact that you chose to see it negatively says a lot.Probably because of the eyeroll comment you left, providing that oh so valuable information that my charge pipe will contain positive pressures. If you mean that as a genuine comment then that is insulting at best.
I never put a temporary brain fart past anyone, and I don’t assume anyone knows anything. Let it go.Yes, it says you think I don't know the charge pipe has positive pressure in it. C'mon now. If anything you're being a smart ass and I can at least buy that. Telling someone there's boost in the boost pipe, that's ground breaking information.
What value is putting the sensor in the intake path? Like what meaningful data do you expect to collect? Unless the filter is a restriction of course, even then...
How many times do I need to tell you it was a serious comment. You believe whatever the fuck you want though. I’m done.Sometimes when I wake up in the morning I say stupid shit but at least I know it's stupid shit.
This is 100% a troll comment or just plain old sarcasm, I can accept that. Trying to say otherwise is 'stupid shit'.
He wants to see if there's any meaningful vacuum pre-turbo while in boost or if it's still effectively the same as just going VTA on the high side. His whole goal is to simplify the PCV system, so I'd imagine if he finds useful vacuum there he'd have that be his (sole?) crank case vent. Worst case scenario is he confirms what he already suspects. Science![]()
