To report the limit of my fuel system. Not sure if it still the venturi valve that cause issues, or simply maxed out my setup.
- HPFP drop to 5 ( 5x 150psi = 750psi), normally we want around 1200psi minimum at high rpm and wot.
- LPFP went from 72psi to 54psi.
- Trims went up.
However, before this big drop, timing jumped to 6.7° to 7.5°.
AFR are good, probably because of the meth injection.
Still annoying, this is around 480whp, I was expecting a bit more from a 94oct fuel + meth 50/50 + 450walbro. On a 6262bb gen2 turbo.
I'll drill out 1/16'' the fuel rail to see if I can get a couple hundred psi.
datazap.me
