Hey there lads. Never thought I would have to post on forums for help but here I am. I have a 2008 335i (N54).
So recently my car has been feeling horrible and having symptoms of HPFP failure
1. Rough cold start
2. Feels like misfires when under mild acceleration.
3. If I accelerate for more than a couple of seconds the engine shakes and violently jerks the car, cutting the turbos out and shutting off the HPFP. Rail pressure drops and matches the low-pressure fuel pump (85 psi). This causes the car to blast the radiator fan to full power and go into limp mode. I can temporarily solve this by shutting the car off and on again.
Oh and another thing.
4. Odd high pitched siren/whistle sound when under acceleration and metal clank noise? But no wastegate rattle. Might be a separate issue?
Codes :
29f1 - Fuel pressure plausibility
29cf- Misfire (probably caused by the drop in fuel pressure)
Since I know it's pretty common for our HPFP's to fail, I ended up buying one off FCP euro for $780 and installed it.
BUT unfortunately no luck. The car still violently jerks and shuts off the HPFP and I don't know why. I'm losing my damn mind with the car and I've only had it for a year.
I managed to make a quick log after installing the new pump showing the fuel pressure dropping and skyrocketing my afr:
datazap.me
And this is what INPA showed in error memory:
It appears that the P-Code assigned with the 29f1 code is P3284. Definition: Fuel pressure control Bank 1 calculation of adaptive fuel volume implausible.
I'm fairly new to the car scene so any help would be greatly appreciated!.
1. Rough cold start
Codes :
datazap.me | angelz0418 | Crap
