Lean Spool - Reference Table?
rac
341
203
135i ST
I capped my Fuel (Spool) table to 14.7 with no ultra-lean areas (and kept lean spool enabled) thinking that lean spool was referencing this table.
But this was not the case. So does this mean we are unable to modify the lean spool AFR targets while in this mode?
Related question, if I disable lean spool and modify the Fuel (Spool) table, will this table then be referenced allowing custom spool AFRs?
RSL
500
It references fuel (spool) in fuel mode 20, but lean spool logic is a separate on/off toggle. Uncheck it and should target fuel spool AFRs uninterrupted then.
rac
341
203
135i ST
Thanks, I did this and confirmed that to be the case
Jake@MHD
Nov 7, 2016
1,587
2,047
Philly
I'm sure there is a table in there that the "Lean Spool" toggle uses, but I don't really see a point in looking for it, as I don't see any positives. Fuel (Spool) and Fuel (Main) should cover all people need.
RSL
500
...just find the +200HP flag :D
