Note: Orders will be fulfilled late August
VRSF Stainless Steel Muffler Delete
For your 2014-2017 BMW M235i with the N55 Engine
We are proud to introduce our VRSF Stainless Steel Race Muffler Delete for the N55 F22/F23 BMW M235i. This muffler delete is one of the most cost effective exhaust modifications available for your N55! By eliminating the incredibly restrictive OEM muffler, back pressure is reduced significantly which results in faster spool, an increase in power & a more aggressive exhaust note. We use a unique CAD/CAM designed cast stainless steel merge collector for the smoothest division from the single exhaust pipe into two individual muffler outlets.
This product was designed and engineered for to fit on both the F22 & F23 M235i in both RWD & AWD configurations. The difference in both power and sound are be noticeable the moment it is installed! Please note that cutting of the factory exhaust is required and that we include everything necessary for installation including installation hardware. This exhaust is available in multiple 90mm tip configurations displayed below.
Features:
- CAD/CAM designed merge collectorfor seamless flange to pipe transition.
- Hand made from mandrel bent, tig welded 2.5" 304 grade stainless steel.
- Brushed finish with the option of Bright Polished, Chrome Black or Titanium Tip finish.
- Smooth radius bends to decrease turbulence and increase flow.
- Quicker spool and improved exhaust note.
- Fits RHD and LHD models with no modification neccessary.
- VRSF Lifetime Warranty against defects and fitment.
- This item fits the following BMWs:
- 2014-2017 F22/F23 BMW M235i & M235xi
