Hello thank you for responding, im sorry if this has already been covered but, I need somewhat of specific advice. I recently purchased 3 index 12 ebay injectors, to swap into bank 1. Upon arrival I was bummed out to see they all had the same flow rate, so they couldn't be calibrated properly. I believe the injectors I have in bank 1 may be leaking due to fuel smell on cold starts. My question is, should I use my remanufactured injectors that are tested and should definitely not leak fuel but cannot be calibrated accurately, while i save up for genuines? Would it be better to find some newer older revisions instead? Thank you for your time
