HPFP, rebuilt or brand new ?
SlowE93
1,655
Just a plane ticket away !
E93
Who here as swapped out their HPFP ? Did you use rebuilt or brand new ? Purchased from ?
Looking to swap mine out. I can replace either way, but if a rebuilt is just as good and half the price, ill go that route. If brand new is the best option, where is the cheapst to purchase from ? Thanks in advance.
1,066
My son is parting out his 335i. I think he still has his HPFP.
No info on how old it is but I'm sure it was replaced back when they all were under the recall. His car ran strong with MHD Stage 2 so it seems the pump should be good.
SlowE93
1,655
E93
Thanks but mine has not failed. It is having a little bit of a struggle on straight E85 , pi, and about 600whp. Original and 75k on motor so just looking for a fresh one to throw in there.
pysical
471
108
2009 335xi E90
If you decide to purchase one from eBay. Make sure it isn't through "DrFuelPump". I purchased one from him and although it says it has a lifetime warranty, they don't reply to you when you need to swap it out.
SlowE93
1,655
E93
Good to know, thanks ! I wanted to go FCP but they are out of stock. ECS has rebuilt and brand new. Just wanting to see if I can get away with rebuilt with what im running, or if brand new is a better approach.
3,592
I'd like to know too ... rebuilt or new. Is rebuilt just as good? It's unclear to me what wears out and gets replaced?
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Mine is rebuilt from FCP. Have about 14k miles of full e85 use no issues.
ECS seems to have the pump in stock with the same part number as the one I got from FCP.
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Another question. Anyone know the power limits of a HPFP on E85 ? Port injection equipped.
Kind of a moot question as you would just turn up the PI duty cycle and/or get bigger port injectors.
DI only the HPFP maxes out around mid to high 400s whp.
SlowE93
1,655
E93
Thanks for those responses ! Yes im aware of turning up pi to relieve hpfp. Problem is, if I do that, trims start crashing since DME sees too much fuel.
You cant buy hpfp pumps brand new they are all rebuilt even from bmw.
Don't know why some sellers are saying they are brand new but when you look at the part number on the pump its old version
The only difference im assuming the remanufactured ones are only partially rebuilt and the more expensive ones are totally overhauled
Ive seen a few remanufactured ones fail but if you have a warranty like fcp euro who cares just keep swapping them out
SlowE93
1,655
E93
Good to know. I understand the FCP deal as I have purchased from them before, HOWEVER, I dont care about spending double if it will have a higher reliability rate. But you say there is no actual brand new hpfp available so......
3,592
p/n 13517616446 FCPEuro has it for $370 shipped with lifetime warranty. BMW of Fairfax does it for $311 shipped.
SlowE93
1,655
E93
Is that a newer version or the problematic ones ? Rebuilt im assuming ? Once again, this is only to try and resolve a hpfp dip in my logs. 99% of my log is CLEAN. just a quick drop in hpfp and then it jumps right back up.
