Fastest N54 XI? Post it up!
Slow335
31
11
09 335i xdrive
Definitely not out to be the fastest xi but I'll be having my VM 6062 kit installed soon so hopefully will be hitting low-mid 500s
Reactions: Travis
Travis
19
Empire state
2008 335xi sedan
What mods are you running? I'm currently working on my xi. id like to make it a little quicker but nothing crazy.
jdm5596
43
16
Texas
I feel like if we could get some drivetrain upgrades, the auto awd platform could surpass all the others. Xi already does well in 1/4 with lil mods
Boosting4me
13
Just finshed up my on3 61mm auto xi looking for 600whp
Boosting4me
13
Would the stock transfer case handle 600?
Well its more torque than anything at 600 hp thats usually around 500 torque it feels safer than stock turbos fbo as the torque isnt as harsh.. and its vitually impossible to launch it hard on this torque convertor with boost not coming on till 3600
jdm5596
43
16
Texas
Tcase is fine, i have not heard anyone report tcase failure from high power level, only front diff...
jdm5596
43
16
Texas
But im thinking if we code to have most power go to rear, it would relieve alot from the front diff. There was a write up on how to do that, ust gotta find it
Reactions: Cheezy and Travis
Travis
19
Empire state
2008 335xi sedan
That would be great if you could find the process of transferring more power to the rear, I didn't know that was possible.
jdm5596
43
16
Texas
Theres a right up if you google it. Someone was coding it to be 20/80 i believe. Which that would be freakin awesome. Ill have to look into it again
jdm5596
43
16
Texas
Really need a way to disengage the front with a switch and be able to do a burnout then rengage it for drag strip tire warm up
jdm5596
43
16
Texas
You have to do more than 26, i pulled 26 one day to try it out, and if you spin to much it cuts throttle and throws a code
Cheezy
611
225
Toledo Ohio
Disabled traction control? Idk I've never really wanted to toggle it so my knowledge on the subject is limited. I know that after 100mph it switches to rwd so it has to be possible. As far as making your xi the fastest in the 1/4 I'd say the single most effective way would be tons of weight reduction
