We are doing everything we can to get some power to our top mount turbo F30. Making the turbo kit was the easy part I guess, that's what the shop is setup to do. Now eveything around it starts to become the bottleneck or in this case shatter into pieces when boost gets cranked up. I was only at 18psi when the stock plastic charge pipe decided to go, after taking it out I am surpised it holds stock boost. I only found one company that made a high quality replacement part and was a little shocked to see the pricetag. I figured what the hell it can't be that hard to make one pipe
and maybe offer it to others.
I had some spare N54 charge pipe parts laying around so I went to work. Got the upper pipe almost done, just need to add meth bung, map sensor flange and a small fitting. You will be able to use your stock o-ring and retainer clip. I am not the best welder in the shop so expect way cleaner parts when it goes to production.
Question for you guys. What color is everyone into? I like the brushed look personally but there is also an option to powder coat them black or full out polished.
