dropped adjustment nut, shock tower access?
Seaneezy
133
34
e90 LCI 335i
This is really embarrasing. I was changing my rebound stiffness on my ohlins and dropped BOTH adjustment nuts in the shock tower housing, I was fishing in there with a magnet and couldn't grab it, so I took off the wheel and wheel well housing but I can't access the shock tower housing from the well. These fuckers are like $50 each, anybody have any idea how I can reach these? My suspension is at the softest rebound at the moment, feels like a Cadillac but my skirts are scraping the roads after bumps
1,929
664
Can you try blowing compressed air in their to get them to move around and get an idea where they are?
3,644
Pick tools. Cheap at your local parts store but I have to say I keep going back to the o-ring hook and scribe set I bought from Harbor Freight. Really good feel, nice reach, etc. Specific to feel, you hold it metal on hand (instead of a plastic handle) so you can really sense what is going on at the tip.
And if you are having a hard time seeing, recommend buying a borescope. This one works well and has good resolution. Stupid crap like this is always and excuse to equip myself with more tools.
4,350
Oh boy, good luck. These moments are quite frustrating, and never in the DIYs.
Seaneezy
133
34
e90 LCI 335i
Update: I bought a flexible magnetic stick from my local hardware store. Took about 30 minutes but I got one of them out. The magnet is not strong enough to completely lift it out of the housing, so I had to do some hand gymnastics. Have not found the other two yet, they are really dug down there.
3,644
I keep a stock of KJ Magnetics N52 magnets around. You've never seen magnets this strong. They are sold with plastic separators as the only way to take them apart is to sheer them apart if they are touching one another.
1,929
664
Could try balling up gorilla tape sticky side out around a long rod curved or if you have flex spring grabbers something like that and roll it around in their will almost def grab if you manage to touch it
dyezak
1,767
1,518
Plano TX
335is
Amazon has some cheap iphone bore-scopes. Tiny cameras that are meant to go into spark plug holes with an LED light so you can inspect combustion chambers.
I bet you can use one to find these nuts. (they are $30 for the cam last I looked).
3,644
Ya'll really need to be reading the Buy This Not That! thread started by @NoQuarter :grimacing:. We got a recommendation for that.
NoQuarter
1,662
1,067
Indiana, USA
Z4 35is, 535xi, X5 35i
yep! I added that to my shopping list. There are some optional attachments for it that includes a magnet, a hook, and mirrors of different angles.
