Hi guys,
so I've been running GC turbos for over 2 years. While street driving I normally limit boost to 24 psi. On the drag strip I've gone to 27 psi with more aggressive timing and luckily everything remained intact.
People have said that the connection between the drive shaft and the diff is a weak point. On 335s the driveshaft is connected by a nut. On the E9x M3 its a big CV joint.
https://www.realoem.com/bmw/enUS/showparts?id=3R92-EUR-07-2013-F82-BMW-M4&diagId=26_0276
e9x M3
https://www.realoem.com/bmw/enUS/showparts?id=WD93-USA-09-2006-E92-BMW-M3&diagId=26_0239
However! The latest M3 and M4 also use the nut as a connection, to a different type of diff. The F90 M5 also used a CV joint.
M3/M4
M5
https://www.realoem.com/bmw/enUS/showparts?id=FV92-EUR-03-2011-F10-BMW-M5&diagId=26_0239
It seems strange that BMW should give an M4 the nut type connection while the previous M3 with much lower torque had what looks like a stronger connection?
Anyway. My question is, can we 335i owners upgrade this connection. I know going with the e9x M3 driveshaft and diff will replace it, but I have a DCT with a 2.56 final drive ratio.
The M4 diff is 3.46 apparently. How much torque will this nut connection take? I'm also based in England which makes importing upgrades very pricey.
e9x M3
M3/M4
M5
