OEM Terminal Socket Identification
I am Jacks N54
83
Ventura, CA
e90 335i
I'm trying to track down the correct male "Terminal Sockets" that connects the OEM harness to the N54 MAP sensor on the top of the intake manifold, but I have no idea how to identify them correctly. One looks to have some corrosion issues that I think are triggering random and annoying 2ABD codes.
Is there a way to make sense of the madness? https://www.realoem.com/bmw/enUS/partgrp?id=VB73-USA-03-2007-E90-BMW-335i&mg=61
Apologies if this is the wrong location to ask this.
That4chanhackerguy
so those are the female pins you crimp on the wire you can cust and strip about 2-3mm of insulation and crimp that to the wire then insert it back into the plug. to depin is supereasy there is a flap on the backside you need to pry open and then depin just like you do with a wire in the DME harness. those pins will work however with it being a Map sensor wire I would encourage to get the silicone insulator as well to keep it water and oil tight
Reactions: I am Jacks N54
