DCT read out Statistics Launch Control counter
pe7er
15
Hey guys, maybe someone has an idea ?!. I am not able to read out the Launch Control usage counter in german "Anzahl der Rennstarts" , neither via INPA nor with Tool32 using DKG_90.prg. All other parameters could be read like the current clutch pressure or the temperature of the transmission, but the function block "Statistikdatensatz_1_lesen" throws every time the error message: Edibas Error 19 : IFH-0009 no response from controlunit . it seems like there is a protection to prevent to read out the statistics data 1 .
pe7er
15
it's a e92 335i with N54 and DCT from 2009/04.
yes, it has launch control
HW-Nr: 7601968 and ZUSB: 7601973
as i said, other parameters can be read-out from the dct, but the statistikdaten 1 throws me that error
2,271
817
Have you personally seen it being used on that car ?
RSL
503
Might be M DCT only. Smokey burnout counter is in there too and that's M only. Non-M DCT Sport is program mode 1 and stays in 1 even in launch mode, but DKG shows 12 modes available. 1-6 are drive logic and 7-12 are launch control. Clear there are things in there not related/used on all DKG setups.
pe7er
15
got it :) , the solution was to buy the bimmergeeks cable and now works as expected !
I am glad to see the 0 as launch control counter value :D
Reactions: RSL
pe7er
15
in the right order:
- request gear without braking
- request rear gear @ v > rank threshold
- automatic P-Mode when leaving the car
- request P-Mode @ v > 5kmh (parking hook i guess)
- launch control counter
Reactions: aus335iguy
RSL
503
Surprised this is cable related, but thanks for posting. I can't read any stats from any module and they seem to be the only things. Been using the one stop cable for 5 years without issue, but maybe I'll order BG and see if it reads them.
Reminder: put in Park, then open the door lol
KClemente
315
172
E90 335i
Is there a way to read out the max rev counter? Ista isnt showing me anything of use.
Someone said on the 1 series forum "Maximum RPM Achieved is under service functions -> engine -> data -> RPM Limit. That will tell you everything in ISTA. " but it doesn't seem to be accessible for me
RSL
503
I've never looked for it personally, but I might drag the laptop out to the car for some coding today, I'll poke around if I do.
