Mileage: 109k
Mileage: 170k
Both vehicles were 100% stock when I bought.
No maintenance records. But No issues presently.
Matt Malave
⚫️ +1 (973) 945-2727
www.znmperformance.com
Next to Harbor Freight and bought my Walnut Blasting Gear. Links to what I bought will be listed below. Then got on BavAuto and purchased my BMW OEM Port adapter for the intake ports which connects to any Wet/Dry vacuum. At the time this was $89 shipped and arrived in 3 days. Link below.
https://www.bavauto.com/bmw-adapter-81292208037
Maintenance:
I performed the trans maintenance, changed the plugs, checked the OFHG and VCG for leaks. None to be seen. I also checked my WaterPumps visual condition previously and seen it was already a new unit, so I opted not to replace it again. I’ll post links for all these items anyways.
Water Pump Kit:
http://znmperformance.com/bmw-n54-waterpump-kit-11517632426znm/
NGK 95770 Spark Plugs:
http://znmperformance.com/bmw-ilzkbr7a-8dg-spark-plug-ngk-95770/
Eldor N54/N55 Coils:
http://znmperformance.com/bmw-direct-ignition-coil-eldor-12138657273/
Delphi N54/N55 Coils:
http://znmperformance.com/bmw-direct-ignition-coil-delphi-12138616153/
BMW OE Oil Filter Kit:
http://znmperformance.com/bmw-engine-oil-filter-kit-mann-11428683196/
Victor Reinz OFHG:
http://znmperformance.com/bmw-engine-oil-filter-housing-gasket-reinz-11428637821/
Victor Reinz Valve Cover Gasket:
http://znmperformance.com/bmw-valve-cover-gasket-victor-reinz-11127565286/
ÜRO Valve Cover:
http://znmperformance.com/bmw-valve-cover-uro-11127565284/
BMW Genuine Coolant:
https://www.amazon.com/gp/aw/d/B014...mw+coolant&dpPl=1&dpID=31k1nTOUhyL&ref=plSrch
Remote Coding:
So initially I had some coding issues I wanted reconciled. A faulty TPMS, Headlight Errors, faulty brake pad sensor, and other small issues. Please guys, contact Dylan Strickland at BimmerGeeks for any and all coding needs. He’s super helpful and a wiz at whatever wizardry it is that he performs lol. He coded my car remotely while I ate dinner w/family. He also hooked me up w/ a new Data Cable after the cheap Amazon Cable didn’t work, and overnighted it to me via FedEx.
What he did:
- Alpina Transmission Flash
- Coding out my TPMS errors
- Coding out my headlight errors
- Added comfort access functions:
- Digital Speedo, and even a few
more things I haven’t even seen yet.
Dylan Strickland
www.bimmergeeks.net
After maintenance and coding error correction, I decided to start sourcing my FBO and tuning options. I bought used HTC M8 Android for $20 and downloaded MHD for N54 from the Google Play Store.
Now that I have MHD installed, Purchase the Monitoring, Flasher Module, and Stage Tune Pack you desire. For me it was the Stage 2 and 2+ Map Pack.
Now to start sourcing my FBO parts.
So for that I’ll need:
What I bought:
- VRSF 3” Catless Down Pipes
- VRSF 335D Charge Pipe
- VRSF Race Front Mount Intercooler
- VRSF Relocated Silicone Inlets
- BMP PNP Stage 2 LPFP
- TiAL Q Blow Off Valve
______________________________________________________
UPDATE: I am a VRSF Dealer so you you can order your VRSF / MMP / Revshift / ViE / Misfire Racing / parts directly through me also!!
Email or PM: [email protected]
Or buy through the N5X /// WORLD store.
Don’t just ask what everyone else bought or you’ll likely over pay, or end up with an untested or improperly designed product. From my research, 90% of the DPs available are stainless steel welded bends manufactured in China, and sold here in the US for $200-$400 a set. I found the VRSF and 1320 DPs are the ONLY DPs that utilize the superior Mandrel Bent design making for a significantly smoother inside finish with almost no chance of cracking or breaking welds. Using fewer welds also allows the DPs to maintain a continuous 3” ID throughout. BONUS: They are also are priced much less than companies offering what I consider to be an inferior design. I chose VRSF this time around for the ease of fitment as the 1320 DPs were a very very snug fit in my e93 and caused a little more pain during the install. I had no fitment issues installing them, although fitment is extremely tight while installing the front turbo DP. So if you buy these and have an issue, PM me, I’ll walk you through the install. VRSF 3” Mandrel DPs available now, fit like a glove and were very easy to install. No swearing necessary. Either I recommend, tho for convenience, and function, and Lifetime Warranty, go with VRSF.
http://picbear.online/media/1624887768940054391_421991623[\IMG]
When I was choosing a Low Pressure Fuel Pump, it was just a matter of who supplies one with everything needed for PNP at a competitive price. Black Market Parts hands down was by far the best deal available, as well as the most attractive kit for the money. Fuel it was another option as well as Vader Solutions. However For the money and product build quality, BMP couldn’t be beat. I PM’d them at BMP when inquiring, and they were very informative. They asked what my power goals were, other fueling upgrades planned, etc. Then set me up w/their Stage 2 kit, and shipped it out the next day. Best part, if you’re patient, They’ll even walk you through the install if needed. In summary I got a sick deal, and couldn’t be happier with the product thus far. Only 4 days from ordering to my door.
Contact Name?
[URL='http://www.bm-parts.com']www.bm-parts.com
The VRSF is simple. There are probably a thousand or more out there now and they’re the first and only proven FMIC to hold 1000WHP on a Dyno. So simply put, VRSF Race is a win every time. Hands down.
On my previous build I bought a 900ic. I did so because Dusty Waterfall at PSP really knows his stuff. I watched him post comment after comment explaining fluid dynamics, IATs, fluid pressure, airflow, and more. Add to that the 900ic unrivaled beauty, and how the PSP also uses an HD Core w/FPI of 18. I chose to get one as well.
I have to say, they both get the job done. Both controlled IATs beautifully. Neither shown any signs of boost leak. Both are very attractive behind the grill and both are comparable in price.
The PSP FMIC is by far the most beautiful I have seen from any other vendor. His welds are so clean they look machined. Both the VRSF Race and PSP 900ic include quality T-bolt clamps, Mounting Hardware, and include couplers, and a lower chargepipe.
In summary I’ve bought both now, and have nothing bad to say of either. I do currently have the VRSF Race on my e92 Single Turbo build as it’s proven to handle the highest power level, which I’m going to need when I install my newest kit being built by Jon Vigil at ViE.
Also, tank design, anyone who has a basic understanding of fluid dynamics will agree that a cast, smooth curved end tank will flow more efficiently then hard angled sheet metal end tanks. That said the VRSF may not look like a work or art, but in this case FORM < FUNCTION wins.
Tiago Viera
www.vr-speed.com
https://scontent.cdninstagram.com/vp/0e42c4be6ff00ffb42cfe9cdc9f277ed/5B790341/t51.2885-15/s640x640/sh0.08/e35/31421681_1833149320084488_7535834843150548992_n.jpg
Dusty Waterfall
www.fasterbypinnacle.com
So let me start by saying, you bought a BMW. The ultimate driving machine. A Performance Luxury car if you will. All the people running those ghetto looking DCIs that cost $69-$129 for two pieces of plastic pipe, and generic cone filters, how can you put such an ugly product in such an otherwise attractive engine bay? I kno I kno, it’s about the FUNCTION > FORM... well for me that thought process doesn’t register.
I wanted my engine bay to be pretty. So on my old e93 I installed the Injen DCI System. This in my opinion is the best looking DCI setup for the money. It’s around $349 shipped. It looks fantastic and sounds amazing. If you want a nice looking Performance Intake, and don’t want to upgrade to 40% higher flowing Relocated Inlets, I strongly suggest and endorse the Injen DCI kit.
If you must and can’t afford $349... don’t want to do the work installing inlets, but want improved intake performance, BUY THE PSP DCIs. At least they’re quality filters, and Carbon Fiber Pipe connections. But still these kits look like a mid-90’s Single Cam Honda; eBay Intake IMO.
PSP DCIs: https://fasterbypinnacle.com/product/air-filters/
Some of you may remember my previous thread where I wanted to run HiFlo Pod Filters on my stock twin turbos (like the larger filters on the Single Turbo guys cars. DONT DO IT. We’ve beta tested three different flowing pods and all caused excess pressure inside the compressor housing ultimately causing severe internal turbulence and eventually failure of the turbo seals.
JUST SAY NO TO PODS:
So after fighting Silicone Radiator Hose’esk Relocated Inlets for almost a year... I caved and and surrendered to the data. +40% improved flow over stock inlets. It’s the highest flowing performance option available to date... however, still, this is where I have a problem. Of all the bright people out there developing performance parts for our cars, silicone relocated and or OE location inlets can’t possibly be our only option right? I mean melting radiator hoses? Really? The sad truth answer, yes. They’re our best option for getting the most power out of our intake system.
To be frank, the majority of complaints Ive seen, I’ve come to realize could have been prevented if there were a proper step by step DIY install to follow. Incorrect installation, usually resulting in melting the inlet doesn’t have to continue, and I’ll post a link here when I’ve finished it:
In summary, you have a few intake options for improved performance.
Tiago Viera
www.vr-speed.com
Mauricio Madrid
www.mmp-e.com
Jake Ulch
www.facebook.com/N5XWORLD
Dusty Waterfall
PSP Dual Cone Intakes
So here I am.. I’m FBO. Everything is installed. Engine cleaned. I’m ready to flash. As mentioned above, I elected to skip the MHD Stage 1 OTS maps and went straight to MHD Stage 2+. Done.
Ken has tuned both my cars and countless others. He’s a great friend and even better tuner. Trusted. Reliable. And true to the premise of this thread, he affordable. Tunes start at $300. Go see Ken and get a custom remote tune on your car. You won’t regret it.
Ken Atkinson
www.wedgeperformance.com
Real quick, I also bought some little cosmetic things cheap. Amazon and eBay.
Courtesy Logo Lights: $12
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/222717284076
Matte Grills: $28
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/112294863317
Gloss German Grills: $33
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/132335872166
LED Halo Bulbs: $38
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/141836273762
For people wondering. After installing everything. Performing all the maintenance, and flashing MHD Stage 2+, I can report, knock on wood, I have zero DME codes or errors. None whatsoever. Call it luck. Call it a glitch in the DME.
Either way, things look promising based solely on the lack of DME codes and the overall feel of what I would say is a healthy, happy, performance engine.
So I’m stoked.
- [email protected][/URL]
