Full OBD MHD Flasher released for F-Series
4,345
Finally we get to see the MHD Flasher for the F chassis cars and it comes to us in the full OBD flavor, no need for a one time 'unlock' bench flash. They don't call for an initial backup but they do claim the car can be reverted to the factory flash at any point. This release will start with a beta period on New Years 2018, and should last approximately 4-6 weeks until public release. This will support N55 EWG and PWG as well as the S55 in the F8x M3/M4 with support for N20 and S63 coming in 2018.
Further notable features being developed include: Flex Fuel, MHD Wireless OBD2 adapter, on the fly map switching, real time tuning, anti-theft and more. The cost for N55/S55 is $249/$299 plus any map packs/modules.
Here are the full release notes:
The MHD tuning team is proud to present its latest product - the MHD Flasher for BMW F-Series. After two years of development, the wait is finally over!
The MHD Flasher F-Series is a complete flash tuning app for your BMW. Unlike a piggyback module, it is capable of complete DME remapping while retaining all OEM safety mechanisms. This allows for maximum performance,maximum safety, and unrivaled drivability.
Several thousand customers worldwide have been enjoying the number one flash tuning tool for the E series N54 and N55 platforms (MHD Flasher N54 / N55 E-series) since 2015. Come join us now for the F-series launch and see what all the hype is about!
Release schedule:
We will start a closed beta period from 1-1-2018. Users willing to actively participate and provide datalogs can drop us an email right now ([email protected]). We'll provide a coupon for the bimmergeek cable.
Expected closed beta period is 4-6 weeks, after which we'll go public.
***Product details:***
**Full OBD Flashing:**
You can install MHD right at home and start tuning immediately! There is no need to remove and send out your DME for a costly “unlock.” Simply download the MHD Flasher F-Series app that connects via a K+DCAN cable to your Android device and your vehicle’s OBD-II port, start the app, and within 25 minutes the initial installation is complete. Further map changes are much faster - only 3 minutes! You can revert your vehicle to the factory OEM flash at any point, and no initial backup is necessary.
**Stage 1, Stage 2 und E85 OTS (Off The Shelf) Maps by PureBoost:**
We offer a wide selection of OTS maps for the N55 PWG, N55 EWG and S55 engines suitable for many different vehicle modifications and octane levels. They have been extensively road and dyno tested, just flash and go!:
**N55 EWG (Vehicles built after 07/2013 with electronic wastegate):**
-- Stage 1 (up to 360HP/540NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for stock cars. (not available for M2 and X4 M40i)
-- Stage 2 (up to 390HP/580NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with an upgraded intercooler or high-flow downpipe.
-- Stage 2+ (up to 430HP/630NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with an upgraded intercooler and high-flow downpipe.
-- Ethanol Mix Maps: Stage 1, 2 and 2+ E20 Maps for ethanol blends of 20% (in development)
**N55 PWG (pneumatic wastegate):**
-- Stage 1 (up to 350HP/540NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for stock cars. (not available for M2 and X4 M40i)
-- Stage 2 (up to 370HP/580NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with an upgraded intercooler or high-flow downpipe.
-- Stage 2+ (up to 400HP/630NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with an upgraded intercooler and high-flow downpipe.
**S55 (BMW M3 / M4 F8x):**
-- Stage 1 (up to 530HP/700NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for stock cars.
-- Stage 2 (up to 560HP/780NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with high-flow downpipes.
-- Stage 2+(up to 585HP/850NM) - 93oct/98ron, 95oct/102ron, for cars equipped with a free flowing exhaust and high-flow downpipes. (in development)
-- Ethanol Mix Maps: Stage 1, 2 and 2+ E30-E85 Maps for ethanol blends of 30%-85% (in development)
**Topspeed limiter removed on all OTS maps.**
As an alternative to built-in maps, many local and remote tuners can provide advanced custom mapping for those who have more extensive modifications or unique performance / customization needs.
**Monitoring and Logging Module:**
Monitor your engine behavior to make sure it is running perfectly using a configurable gauge layout. 50+ engine parameters are available at a glance!. Activate the logging mode to save the data to a standard CSV file for later analysis using the built in log viewer. Additionally, we will happily provide free logs analysis.
**These are some of the available monitors:**
-- Boost, Boost Target
-- Lambda (AFR)
-- Intake Air Temp (IAT)
-- Ignition Timing per Cylinder
-- Coolant Temperature
-- Oil Temperature, Oil Pressure
-- Transmission Temperature
-- High Pressure Fuel Pump (HPFP)
-- Throttle Position
-- Wastegate Duty-Cycle
-- RPM
-- Speed
-- EGT
-- And many more…
**MHD exclusive advanced monitor:**
-- Timing Corrections per Cylinder
-- Base Compressor Axis: Boost Setpoint, MAF req WGDC.
-- Active Torque Limiters
-- And many more…
**Flash-time Options:(in Development)**
These flash options can be applied to any map directly through the app!
-- Exhaust Burble:
Customize your desired exhaust burble (duration & aggressiveness) and enjoy the sporty sound
-- Torque limit per gear
-- N20 Map Sensor (on N55)
-- More options will follow with new updates.
**Read DME Codes:**
Track issues by reading the error codes, and delete them once resolved.
**New features and updates:**
The MHD Flasher F-series will continue to evolve after the release, which means many exciting new features and map updates will be coming in the future. The following projects are currently in development for 2018:
-- Flex Fuel
-- MHD Wireless OBD-II adaptor:
-- On the fly map switching
-- Exhaust flap control
-- Quicker flash times
-- Real time tuning
-- MHD anti-theft protection
-- Valet mode (reduced power and limited rpm)
***What you need:***
- Android device, OTG compatible with Android OS 3.2 and higher.
- BimmerGeeks ProCable (K+DCAN cable).
***Supported vehicles:***
**MHD Flasher F-Series N55:**
-- M135i F2x N55 2012 - 2016
-- M235i F2x N55 2013 - 2016
-- M2 F87 N55 2015 - 2018
-- 335i N55 F3x 2011 - 2015
-- 435i N55 F3x 2013 - 2016
-- 535i N55 F1x 2010 - 2017
-- 640i N55 F0x 2011 - 2017
-- 740i N55 F0x 2012 - 2015
-- X3 35i N55 F25 2010 - 2017
-- X4 35i / M40i N55 F26 2014 - 2018
-- X5 40i N55 F15 2013 - 2018
-- X6 40i N55 F16 2014 - 2018
-- X-Drive is supported on all cars.
**MHD Flasher F-Series S55:**
-- M3 S55 F80 2014 - 2018
-- M4 S55 F82 2014 - 2018
-- M4 S55 F83 2014 - 2018
***Pricing (In-App purchases):***
**MHD Flasher N55:**
Flasher license: 249$
Monitor license: 99$
Map packs: 99$ each
**MHD Flasher S55:**
Flasher license: 299$
Map packs: 149$ each
