Custom HIGH PERFORMANCE Headlights
TwinTurboWagon
217
235
San Diego
Greetings SS,
Full disclaimer I do headlight retrofits so if anyone needs work done, feel free to reach out to me at [email protected] mention you are from Spool Street and I can include a discount on your build. FB and IG @VisionAutoLab
I am sharing the recent headlight project on my personal E61. 90% of the BMW headlights "builds" I see include paint and LED halos which in my eyes is such a missed opportunity as the light output and performance isn't increased. It is like slapping an M badge and exterior pieces to your car, sure it looks cool and purposeful but performance is exactly the same.
I understand that some people are only concerned with aesthetics and that is fine, to each their own, but most others, even hardcore enthusiasts, are not familiar with the performance a proper headlight setup can offer, please use this thread as an example of what is possible with a proper headlight retrofit: improved Function and Form.
While my wagon was undergoing all the winter upgrades a fellow E61 owner asked to purchase my headlights, I was planning to rebuild my set anyway so I took him up on the offer.
This was my old headlight setup (Version 3):
https://www.hidplanet.com/forums/for...ack-demon-eyes
With my current headlights gone I needed to re-retrofit my original set of lights (Version 1):
https://www.hidplanet.com/forums/for...ustom-orion-v2
I guess you could consider this Version 4 my "dream build" for this point in time, it is comprised of HID components which I consider to be the best of the best and a clean/aggressive/unique headlights style with a full black out (eye brow included) and an angel eye delete.
Here are the specs.
- Lexus SC430 Low Beam Projectors
- E30 Clear Lens
- Bowl shift
- Shaved "J slope" shield
- Black demon eye
- Shroudless
- D2S 4.0 High Beam Projector
- Shield/solenoid delete
- Black demon eye
- Boosted Hella Gen 3 Ballasts 46w Low, 55w High
- Osram CBI HID Bulb (Low), Morimoto 5.5k D2H HID Bulb (High)
- Full Vader Black Trim "distressed" finish
- Frosted Fins and Eyebrow Strip
The "Dynamic" motorized gimbals were removed in order to fit the SC430 projectors. Many people scratch their head at deleting such a helpful feature, and it is great but the issue is the oem projectors are not great performers so even with them swiveling to aid light placement they simply can't compare to a high-end projector like the SC430. This projector is a low beam only projector which means it does not offer a high beam, consequently I had to add another HID projector for high beam duty which makes these headlights a "quad" setup with 4 projectors.
Dynamic motor and gimbal is OUT, SC430 is IN
g_Vch5zZGEV7u-RsBdkmjOu14xFkczZ3OmzwhppCaozHnCXZO-5uN4ShSD_suQ_CF-E-L2eD6xQkCrdxag=w1318-h988-no.jpg
After some trimming I got the 4.0 to sit flush in what was originally the reflector bowl for the oem angel eyes.
-1qX4sEcOVD-vdrHt4bEgWYg1hXBBFpi1XLOb95JoTg6KSvMEG0SeNk6ANP-r7nJ1XPNXm2Y7OdyuBcPEg=w1318-h988-no.jpg
SqoOYRVrimcJqd0hxKLZwuzDpBAtamjooIeXXzrgnnmyDklVOL0t3Gw0Gu4qB7hl4XjRAC8MVIetFlK-1A=w1318-h988-no.jpg
I was originally going to mount switchback Diode Dynamic strips in the eyebrows but it takes a surgeon's hand to remove the material without damaging the brow, I tried with my dremel and failed, it would likely be possible with an ultra sonic cutter and laser focus, I passed on the mod at this time but maybe in the future...
3v-b1y2J6YG5gS8N6yARkq6KKkHpk90EmnbUtojhlmKbeVcoUGhEji9FSROm2NlsWo2o8CjDkJPH8FrukA=w1318-h988-no.jpg
qVnvS6x3SLZzXYgZ6DY4b8fDbUccGm5GKTJf98IOgU0WoTjQhr96kAD0PW_euP3pdDewwShE0DoR-1gvBw=w1318-h988-no.jpg
FwpizGFe5woGPpy9otga5zg3TCpPFolxaxtZcVJ026z2kZjfQtisRotaBo9UQPDJ8iAa9azz6-P99wR1ZA=w1318-h988-no.jpg
As I was keeping the oem LEDs my plan was to keep the side marker intense but kill off the light shining down the tube. In hopes of doing this I removed the reflector for the large LED, I couldn't desolder it as it would break the circuit.
6G4kCuxB2Lgp8QR6tQIQR8Qrx0Wfi3234g0tSfYfVQDKZL0p-WtCzprjpeSpn-Dx6A_saY1bDP4ujBphdA=w1318-h988-no.jpg
igG-R6rkhBE1m09XmzzzK-r2TDrHKHTOvAqYc_RlT3z3nNM6uddIzbhgFJhpJ4-cKu1xWS95RdJHc2_IPw=w1318-h988-no.jpg
I have a brushed aluminum theme on my wagon inside the cabin and in the engine bay so my plan to was to brush the SC430 and leave it raw so I sandewd everything by hand. Here the lens retrainer on the left is oem and the one on the right is brushed,
I2-FyUApVKHB2NSTSivkDRXAQOalN6hoiczMepPqHv6kY0MbiMSM-Od2GiDE9AwANY-nl8IWdPfubw4Vxw=w1318-h988-no.jpg
_WWrhdf3B56TvaSFJ5mHBiKy15MHlLcgZL6flQMOOX1oUkPtPTEgIRgFA2DhQkmRuYp7GyOm9OC9cju8zg=w1318-h988-no.jpg
Everything brushed
G7Yzs588SFRiAAaCJsA6KCECF-_X8DoHlJ4nvF_jahnu4iQ5CjJR-trbmCZiw40jMY3jH2Jkn3DuSLewrg=w1318-h988-no.jpg
Drilled out the mounts to allow mounting hardware
A4anFqN2LoojlRPKFXo9NvXzOOJ2maRMv6k71vbhM-N3jVfiic8PcPBq1j43O2gM0-kHL35ZDjxMsmF1AQ=w1318-h988-no.jpg
Shields were sanded to create a "J step" and allow a tad bit more light to pass through. My E61 is lowered and have no concerns about the added light blinding people.
xlMz5gXVZYdugdLXGPYcO1WfY4DU35I9dj9Pgr6dAR-nvcN7L--SV2Nqia9iAKaNOi1xnL1pDL5USuaVmg=w1318-h988-no.jpg
Projectors are mounted rock-solid, no wiggle or wobble. The lower tab on the bowl sits nicely on the outer gimbal.
xxRNrIW1axcmKQuljNpvHzvtn9MTrnUPnQsezYcCG72pvbHYyusxDqYGsJoDAaiTxKz8S76wpsZV8-gb1g=w1318-h988-no.jpg
SC430 left, oem Hella Bi-X on the right.
RssalaSYzW9W1mTSEiikKEjqGRMA9kPnRID6bJjuGKyUKA3AfxZxK0OuiHzAfIPSR6jDoA7UR9PuPebUnQ=w1318-h988-no.jpg
Brow was originally silver which was "fine" and unoffensive but I wanted the brow to match the complete look of the headlight, I also wanted to test my skills on extracting and reinstalling the brow. It resides in it's own cavity above the main headlight area. So you could remove it with the headlight lens remaining sealed. It is VERY challenging to remove since it is so visible and when you use razor to cut it out any blemish form the process is easily visible.
qavCEPOUzbFjr6MtrAET0qMuGSUuB6MFoeLLuSuHZyqGZnb_lPS1uevoXIMVJ-B7aC426GeHnUi223ohHA=w1318-h988-no.jpg
Here is the look I was going for; tying the lights and the brushed look into the rest of the car, unfortunately the SC430s were so recessed behind the larger shroud they were not able to be "celebrated" as I had hoped and instead of them being showcased they were tucked away and the silver in the otherwise blackheadlight made it looked a bit unfinished. This was confirmed after I mocked up the headlight with the lenses off.
EzTZ7D0ZKyoGK-SiCOPN5hgMdRyQowan9ebjrkxWkaSqxTqL8Yy6NJKDYTv_YOjAIgi50RRgMqQUmGHYIA=w1318-h988-no.jpg
W0z95_w8w84YpGAoWvXomZIZ-9awGH3WjkH8mXGAms5xsypLnhh0-PMfQUwHPdTNYy1YTGqtFBPQKeo66Q=w1318-h988-no.jpg
AwPYHfNRwSUwxHIbvaaAeh6vkLZOuZBeMm_VVCyWKdPYhwfj6-SL4ubDeyqisOS4Wi29kifW6QcJIF9LjA=w1318-h988-no.jpg
TwinTurboWagon
217
235
San Diego
D2S 4.0s with solenoid removed and black demon eye applied
SC430s after receiving the "Vader" treatment. Being high temp paint with ceramic I put it through a few heat cycles to help it cure and release any extra gasses.
My original wiring harness was in bad shape, luckily I had some extra parts from an eBay light I bought for components. It should be easy to tell which harness is which.
DGQTiGgAo5XO4b_OMimB18b8tJ-OzYUdC7uipRY4-MY1X4PQTeC8qssF2Ak0BokFMUrlRyUUpb1Od5owGw=w1318-h988-no.jpg
fU25doqz-d_zkF5uf92vt01kCZKkRHNJ7AnIPROgRpLb-0EYDF0Gleuk67OhdRxTkIOTKb9keYPRxtKCUw=w1318-h988-no.jpg
eY9vcxZf2ScnFWnP3w_dke5ds7Lrk_-hU4mYO_piMpmbzO8BJnZSS1Lob3B3NQIcjGBqfm5hpvU7Lzdcbg=w1318-h988-no.jpg
d4TxZNp9YA3_LhHEhyY-XrOYbdsiRyP7mZfXOKLt5ZzqZNCek7V7vG4c5_9gpUaIJAaQfDe0_EF2VA1hoA=w1318-h988-no.jpg
ZBViJ8V_WT-Iasnm9oDt7QDNk9L-uYzZ-QngHy-kDvMFgPkv7kl_lXUetv3qEeGZAf5yJkn5lSrfdP7ZjA=w1318-h988-no.jpg
9wufwPpSZRVUyUATItkESLDaZtIwEa5onLgiCHGSOVZ6BeRWoXehzobBURHD0rOL28vGvJ1DZvLfFLAHuw=w1318-h988-no.jpg
SC430 painted, tuned, and ready to go back in
VbscZGQ0AdsMySbn6-oV8u4rKzoKWJvvy6ksp0zDcRf5Gx4L9eeqVzpqqT_o0D_cH1Ygj2WV450Z2PaNJg=w1318-h988-no.jpg
Digital angle finder and a Bosch laser level FTW
4plDqSBAwkr47ISEs-pQPqz_zagep-eUhVhO7bUDpBC3Ai3PrGuCt_F5nXyExGB8XkVhep6AeDMSU6b_fQ=w1318-h988-no.jpg
nGaCk6WX0yHgv_wBAJf8WPVrb61_bSMcKWZcHWGKr-jJz2hADnEGTCgL4o03nNvga7zcC32ehpEEvn9OXg=w1318-h988-no.jpg
Going back in
FOYnzyEih4Q1KBpfYmj6F7Pco5nlwKgJqkIKSDuEvRQ4s2JSHuEBNTDMsejZWcaN3Qtb97PNu5eE8YyvAw=w1318-h988-no.jpg
Love the raw projector look #CelebrateOemProjectors
mxKM0OvgCcFjqSHqQMQB_m2d3kMea4H8xmTASPU57kDpkWAF07XC60A4dHW2s7Hf-myqXQgHOBynQcxwPQ=w1318-h988-no.jpg
You can see the D2S slightly aimed upward.
Fk0bZaSYVwRX5vbIYXrrYnRsvRxl5lBuXLTb6j6gof3EB-nPbHhBOBSUf7imFFJXxwyvpQFHaZ3bls9RjA=w1318-h988-no.jpg
No JB here, just some precise dremeling and serviceable hardware. i wanted to run CBIs for the highs but Mori CBHs were called into duty for space constraints, happy I got the D2S 4.0 to fit in here, previously it was a MH1.
cBLdIi-lYrtvhtpw8Rqk5boL393M9_VxeowPK6IxO3WuNot9khxSkMbwdObQcRknF9fMNVvLoRgm1_WEGw=w1318-h988-no.jpg
Grommets for the CBH
5zaWSsxYpheXdlFG8-SZ3Cm3Z4B0mD-89O_wiqcKLbW7-0FVF5hjmw1KDmZO_yqoT0OnsJ5nB9hxOMImDQ=w1318-h988-no.jpg
Excess butyl after the seal
TL5JB4RO5w4cTw0cZLsbBKeigNpWFu98HHkbwVonwV5c9KLWRtpTEon7DTLkxN4nNyAxAK8q-6gpBPQfcw=w1318-h988-no.jpg
Trimmed
426u2bd_wovnLi-72uog_0YGRMUkRqyPIIYn7kXMV-08XBd2LYEJCQzmZ5brwVnLCeEgIDeMjgGOVcKF7A=w1318-h988-no.jpg
All done, finished up just in time for Bimmerfest 2017
UJRiND5hZzYltMSct8BIXEf8rsZGO2F5DNnusOXFEOV1nEGiUb9Xj06Yd3qTLN5RYgW6hiuN7dZx8fuy-Q=w1318-h988-no.jpg
TwinTurboWagon
217
235
San Diego
ZNU5wtoTnORp-2I0kiV6uW_MhmeyPCF9m7OjZRJTa7tnqI_T-nfh0CS_TcEkioSaWUMb42KdNG24TqMNSw=w1318-h988-no.jpg
That D2S lens is in a PRIME location for some projector burn, I have to be mindful of where I park.
U_t5WsDXTx6_xbToF2Gvh_CwJ7AdO875E2e5PDBUn7fz1CC4lzVWh_t7m-APVfZR7j63EvTs0Mq7luLViw=w1318-h988-no.jpg
Running light
4Y4yhfZDW0PiPMZQXw6-toFfXBBHUQUjsNK2sJVIaG3N5aeg06uCoC-otmDxLyEUseRT6KwCW1rR79z4Lw=w1318-h988-no.jpg
Laser beams
Rt3gd3Ll3HWx6CyJC0ra0iisIGA12ZwnarQOs4LAMwS9fm9xPStGFsQlieoT69KSIoJzqbTqhTG2awp4jQ=w1318-h988-no.jpg
Disclaimer: Acme 75w ballasts are powering the high beam in these pics, NOT the 55w Hellas, (still need to build the custom Hellas), The high beam will be strong but not as face-melting nuclear strong as shown in these pics. The output is INSANE.
Bpdal4FXfbg8l-sLgekdDnchT16rjQqgxxCoFMGs8okmzhSHItKFT-4LbxnBQ-b8H8k1JyLKsLUo2EqIuw=w1318-h988-no.jpg
NW63tb2dQbwXMNiYNTKS-jSSM1wJAEdl02vwMZ_OTsKFrPUEt4TBRDA47UcruUgudjC9GTZVfPy3REWxiQ=w1318-h988-no.jpg
slUymoB5-lY7_U02klmuQNLwo_I2AhMXClDTIwyScqK3G52IXOrAHhMosycBiZpK7Kp8ntFU10I9gUZIpw=w1318-h988-no.jpg
JoNyRggLK00l5LvGVpqidH1wlKfcFiw1G3qsbHwF4JY1AX_jR78DCai_e1hWO1aDsgwBdOoyo6sAhKHYNA=w1318-h988-no.jpg
W6dH72C79mrcLN8d59pz-q5Ngnx2KVbAPHM7oSS6DBafQNpACSTxFlUEMOfmF_HGllmIk-5qgmpm2aC8ug=w1318-h988-no.jpg
BTW this is about 15' from the wall, love the SC430 width.
D1td3QHO-uYltxdGr5P05pLSz8PcPWCzVBbh6mDbCyaVoWzLjPG8JSdXzqYa7mIPLGdFZK7eVYo_xeKqDQ=w1318-h988-no.jpg
High beam champ: D2S 4.0 + Arsenal
7Jx7yMbNX0ymsG05-4MTqWkku4CU_vakNguHj2mOy6L_lbYXZeuUMEbRAvQvnYnOEZs-2bCJJ17ulVxVzA=w1318-h988-no.jpg
Laser beams
bIFOzREv4Iftt7Q9kEfcCL1XwFy-BfK86DnNaQ-kEiGIxI_9XwioeYxNxi0TdLcMRRGsUCzppcKDJ5k79w=w1318-h988-no.jpg
Exposure locked for the following 2 photos
bFe3JICHwkCnx12yqzbQzpbAx2dB4FAXUOpph0msxuctEjuiIopMHwv6uw_bKKpFQjhkQRuSclgtO-59PA=w1318-h988-no.jpg
B9lrd_bF8Wuiid7S89KuuT35pdTKPBOkQ0wuQ6pZlA9MALwDUtXIPO_52QtF2TnwH2tuQ9oKSC2dDH_HEA=w1318-h988-no.jpg
Choppin trees
dwrGAvnWgQbvmB8MTQdpMGdVRonZ8qZxXRHmnlxNlXpBKWIZ2D4ATI44d9Wp8ZKgbjR6R4srEAHWN8a91A=w1318-h988-no.jpg
Gf6wh_473lLc2AifO5acYGv-6uX3TqIaYKmvKxUJMng9fgVD4lqiDBPPQSoK61YunrCghVKrhT2Nr8AP7Q=w1318-h988-no.jpg
Q0ZrKieSxnLhpjc4FxXBubmRIEISxil1prkuYIi8-wfBnSCn22_I0iZM0EQVfpKOm4tbyzW-ry-fO81D5g=w1318-h988-no.jpg
Reactions: ldyzluvdis06
Jsherry20
313
Saw these on the facebook page last night, I just have to say they turned out really well, I'm definitely going to pursue building my own since I have that extra set of lights now. Your light output is just insane lol.
TwinTurboWagon
217
235
San Diego
Nice, pre facelift E92s are easy to open. You will have to ditch the "dynamic" feature to stuff a real bad ass projector in there and it will be a bit of work to retrofit one but totally worth it. Especially since you don't have a time constraint.
Jsherry20
313
Thanks for the tid bits of information, I'm going to start looking into somethings and seeing how I can improve these suckers!
