Crank Hub Silpped
1,685
Shit dude. Sorry for your loss.:(
I'd either buy a refurbed/used engine or add a few thousand and build it. For the labor not worth just replacing parts.
As far as parts lists, I'd refer you to basic stuff mentioned most recently in threads like the BMS 2.0 135i build
V8bait
505
785
Texas
Talk to Tony at VTT. He's had the most experience with this. He makes a product to help, I wouldn't say it's a fix but honestly if you're keeping the motor you need at LEAST any bandaid you can get.
yuli8466
99
23
i rebuild my engine, with VTT hub capture. hard run for 10K miles, the bolt didnt come out. I dont know wether it works :)
VTT has a new crank hub solution other than the crank capture coming out soon. Like V8bait said, talk to Tony
Curious what it costs and if it's as effective as the maxpsi solution.
I heard combining the ppm billet hub with the capture works.
Erichale77
827
447
Clearwater, FL
07 E92 coupe
I'm curious if it addresses both crank hub spin and crank bolt backing out. I'm sure Tony will make a good solution. NOBODY puts things to the test like Tony.
Icewall
18
13
NJ
Great. I need a solution since i cant use the vtt capture hub device with my ati super damper.
kayzrx82
110
88
n54 335i
We have a full fix. No drilling the crank. Labor is same as installing a stock hub. Cost is about half of other options. Look for a post in the next couple weeks announcing availability and all details. We’ll have options for N54 and N55/S55.
Interesting. Do you have any pictures or explanation of how you guys are doing this without drilling the crank? Do you have a time line on its release. ready to order.
