Yes the problem is not the ekp but the factory intank regulator and position of the LPFP sensor and they get worse with
a twin pump setup like a stage 3.
To get rid of oscillations you need to block of the factory reg and install an external one with a return line.
Then you need to put the sensor on the reg pressure reference port.
I also used a fuel pressure damper between the HPFP and LPFP regulator and that stabilised the oscillations
Thanks for the details!
So may I assume the mechanism is:
DME sends signal, based on fuel low pressure sensor readings, to the EKPM to adjust fuel pump duty cycle. And hence the fuel pressure changes. But in factory setup, the regulator is too distant from the pressure sensor(right adjacent to the hpfp iirc), so the regulator adjustment and the sensor adjustment are fighting each other to get the pressure stable.
If that's the case, is it the solution to make reg&sensor as close as possible to stabilize the pressure?
I was thinking it fluctuates because the EKP PWM logic is not updated to the pump capability, which seems to be a little imaginary as you explained your experience
