BMW 335is DCT 11.0 1/4 mile at 137mhp on street tires (26ish-24ish psi)
Mvaccarelli01
121
73
Wanted to share my Timeslip on my first successful Track day when everything on the car finally came together!
2012 BMW 335is DCT STOCK CLUTCH PACKS
Car has not been on a dyno
Getting drag radials on 17s soon low 10s possible?
Tried to go for 10s and up my launch slightly on last pass and spun launch. could of up boost a pound and stayed with the 2.1 sixty but didn't have time.
Feel like this is one of fastest passes with street tires. Think I could of easily had a 10 second pass. let me know what you think
DATALOG- https://datazap.me/u/mvaccarelli/log-1601325568?log=0&data=3-24
Picture of slip and of car is attached..
Instagram VACC_N54
youtube- https://www.youtube.com/channel/UCNT32eKs5sEWtHNDYxUgWeQ?view_as=subscriber
going to be uploading videos of dyno and going back to track day with radials for my 10s. subscribe if interested and want to see!
Turbo/tune
6266 doc race kit GFB Controller tuned by wedge
XHP flash stage 3/Performance launch used (traction all the way off) not standard launch control
Load by gear MHD option checked. 1st gear was limited to 8psi
Fuel
full E85
BMP PI with AIC 6
Stage 3 pump/hobb switch
Upgraded fuel line PR
Bolt ons
2 Step colder plug NGK gapped .022
PR Coils
Evolution Raceworks charge pipe/w synapse BOV
7.5 inch VRSF Race intercooler
Catch can
secondary cats deleted
Suspension/Tires
STA XTA coilovers
wheels Forged apex arc 8
Tires Michelin pilot sport 4s
Front: 18x9 ET31 with 245/40-18 tires
Rear: 18x10" ET33 with 275/35-18 tires
Weight reduction
Rear seats were taken out
ALL maintenance done.
Seems like people struggle to get a good 60 foot with the dct but if you can cut a good 60 foot mid to low 10s should be achievable. Not sure how long the stock clutches will take it though.
Mvaccarelli01
121
73
Yeah definitely 60 sixty foot was horrible with DCT prior to xHP flash release due to launch control was required traction partial on and car with cut throttle.
now I can have traction fully off and set up xHP with to build rpm to whatever I want and ether drop or slip the clutch and it work perfectly. I feel like nothing is stopping the DCT from a good sixty foot and not many people have been testing new xhp launch at track yet.
Brule
392
463
335i 2007 6spd manual
Is the slip recent or from 3 months ago?
I already seen your videos and comented 3 months ago theres no new ones.
17 hoosiers should hold if your dct csn put more power in off the launch. going frim 19 street tyres to 17 hossiers improved my 69ft by .3 seconds on the street.
Anyway yea should do 10s with 17s.
Reactions: Mvaccarelli01
Mvaccarelli01
121
73
3 months ago was old slip, didn’t get a video of the 11.081 pass going to go back with 17 Hoosiers and get good vids.
I feel like the issue with the dct is the gearing. With the 2.56 fist gear is nearly useless for getting out of the hole because you have to be able to grab second very quickly or else you hit rev limiter and the run is ruined.
Mvaccarelli01
121
73
yeah first gear is almost useless that is for sure lol
2,267
814
Retarded timing at launch RPM as well as changes to exhaust timing and a little extra fuel will yield boost on launch
