Anti Surge Housings Explaination
328ijunkie
Many
Tyler wanted me to post this here :)
Since there seems to be some misnomers on the purpose and design of a 'Anti Surge' Housing on a turbo i thought i would save everyone the second of googling it and let it get clarified.
This is Compressor surge:
An anti surge housing is designed to prevent that. It is not designed to take the place of a BOV. it does not relieve the shockwave made by slamming the throttle shut and sending 20+psi worth of airflow backwards in the charge piping and stalling the compressor wheel. it is designed to relieve pressure ON Throttle. It is designed to move the surge line over on the compressor map. Thus the ANTI SURGE. Surge under WOT is 100X more destructive to a compressor wheel/bearing assembly but both are still not good and improper for turbo health. Whether this 'works' for some people is besides the point.
A "race car" running systems in place to pull power when shifting or 'no lift shifting' dont run BOVs because a fully closed throttle blade after WOT at 20+ PSI of boost is rare.
A street car doing multiple aggressive WOT to closed throttle like most of you guys do every day absolutely must have a means to relieve intake pressure.
again there is 20+ links of people further explaining this all over google.
-An Engineer. (not one having done anything in school relating to turbos
4,350
Does anyone have any opinion on the surge housing design? The garret style vs the bullet hole style ala PTE?
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
You largely see on throttle surge when your motor is too small for the turbo. On throttle surge rips thrust bearings apart. Its way worst then off throttle surge.
4,350
But wait, what about my super sweet T51r bov mod? lmao.
Thank you for posting this :)
The spool on my 6266 is already pretty loud at 3k+. I thought about doing it but figured I'd probably get annoyed.
328ijunkie
Many
I've not seen data comparing the ported shroud vs pte design. Likely negligible difference
Agreed. Listen to that YouTube video. Makes me cringe
Lolol welcome!
