ANOTHER DOC RACE ST BUILD & CERAKOTED
Feb 4, 2018
16
2009 bmw 335i 6mt E90
Pictures are always worth a thousand words and Just thought would add some more Car Porn to the site.
  • DOC RACING KIT with Precision JB 6266 Freshly CERAKOTED w/
  • Thermal Solutions LAVA WRAP AND T4 Blanket
  • MOTIV BOOST BOX
  • JB4 BEF with MHD
  • Vadar Solutions ( stage 3 LPFP upgrade)
  • (Have a GARRETT GT4088R DUAL BB TS WATER COOLED installing once i get settled mentally and physically in the single turbo life)
  • Power Flex REAR SHOCK mounts
  • Bilstein B8 Performance PLUS rear shocks ( Replacing blown and leaking H&R premium 16 76 500-1/1 shocks)
  • ECS 20mm front shock spacer. ( H&R Adjustable Racing Coilover Kit RUBS over every bump)
cloud9blue
255
190
09 E92 335i
looking good.
few changes that I would recommend after just finished off my install this week.
- use some stainless steel lines for the vacuum. it gets pretty hot down there.
- I would retap the threads for the O2 so the sensor can get a good electrical ground.
Reactions: medicineman843
Feb 4, 2018
16
Ive got some fittings in route. what size did you use.
i got 4an to M10 x 1.0 i think was the size. and or hope. and certain type of brand for the vacuum hard lineS?
What oil did you use? What turbo do you have?
https://www.precisionturbo.net/PTE-2017-Product-Catalog.pdf
what size tap ?
looking good.
4,348
what size tap ?
M10 x 1.0 sounds about right for TiAL. For vacuum lines, I use these: https://www.ebay.com/itm/172940631491
He will cut you exact lengths if you contact him. I do recommend you get an exact length you need because they can be bulky if you have too much.
I will say, I think I'm going to switch to a nylon hose next time. The stainless braid can scuff and scratch powder coated finishes and even arc off electrical posts turning the line into a big red hot toaster wire.
cloud9blue
255
190
09 E92 335i
what size tap ?
Oil is more of a personal thing. Any true synthetic oil would be more than enough. I personally uses the Castrol 0w40 A3/B4, which is a PAO based oil. I have a Borg Warner EFR7670, not the PTE turbo.
For tap, any O2 thread chaser would clear off the ceramic coating so you can get a good electrical ground.
Feb 4, 2018
16
what size tap ?
I bought Bulk tubing to build my own fittings. pretty much same process that guy did. Im opening my own repair and performance shop so this will be learning experience. Will provide pictures and measurements if i have the time.
Feb 4, 2018
16
WELL guys.
I never could have imagined how expensive this ST Swap would have turned out to be. as of today. Ive spent roughly 12,000 on parts. New index 12 injectors, Stage 3+ LPFP, New HPFP, motor mounts, Suspension, Doc Racing kit, PR coils, NTK O2 sensors, cerakoting, custom built hardlines, lava wrapping....and ONE MILLION hours of my blood sweat and swears.... with more to come probably.
Advice to anyone looking to do the swap to ST. BE PREPARED for everything to start going wrong or breaking. And i havent even turned up the boost yet....
Ive been adding a few logs to work out the kinks in the support section. Want to give a shout out to all the humans that have helped and given quality support throughout the process. will add some more pictures, videos and logs of my progress once i install this new hpfp.
4,348
If you want to do this right, and not a hackjob. Then yes, it will cost a pretty penny. Most people don't speak as much about the corners they've cut. A lot of people are cutting a shit load of corners.
dyezak
1,767
1,518
Plano TX
335is
Tell me about it.
I should be picking up my hot parts from the coating facility this week or next.
08_335i
371
215
2008 ST 335i
Tell me about it.
I stopped counting $ years ago on this car. It just makes you feel better to not know, lol. All you have to do is a "hack job" once on one of these to understand why its better to just coin up, especially on a ST setup. And in the end, like myself, you end up spending more doing it twice, because you tried to be cheap the first time.
Reactions: Shane303
dyezak
1,767
1,518
Plano TX
335is
Yea, and I'm not rushing anything with this build. I'll leave the car on stands for 3mo if that's what it takes to do it right the first time. I don't have anything pressing that I want to use the car for until September anyhow.
Reactions: R.G.
08_335i
371
215
2008 ST 335i
Yep, mine was up on 4 jacks for a little over a month this time. Didn't rush it, fixed all my leaks, made sure to heat protect every damn thing possible, and just made sure everything was done up RIGHT, instead of cheap\quick. There's still a few things I need to finish\do, but the car is running and being driven daily now and the difference between this setup and my last just in smoothness\driveability is night and day.
1,285
779
I look at the cost of mods a bit differently than most, and I also don't count items that are normal items. Injectors, HPFP, plugs, coils - I don't count that stuff unless it's an upgraded version that costs more, like PR coils. Makes me feel better at least :D.
This has been my favorite car to mod yet, and one of the most bang for your buck options available. I think the N54 gives the LS platform a run for its money.
08_335i
371
215
2008 ST 335i
As much as I love my car, and the n54, we are still no where close to giving the LS a run for it's money.
BQTuning
174
140
www.bqtuning.com
E89 Z4 35i 6MT M Sport
Is there any particular preference on the DOC race kit to have the T right off the wastegates as shown in the pic rather than running the T further up to the top where it can be reached ?
dyezak
1,767
1,518
Plano TX
335is
It reduces the amount of hose used and is easily reached. It may look difficult from that pic, but if you saw where the T is you'd have no concerns.
Reactions: TiAg e92
dyezak
1,767
1,518
Plano TX
335is
How much did the cerakote help. Not only for guns lol
There are a lot of independent tests you can look up for Cerakote, Cerakote High Temp, and the best Cerakote High Temp Glacier Series. The glacier coating is phenomenal in eliminating radiant heat transmission.
