Leo1984
Datalog A 19t e20 target 20psi
What trans do you have? Things look a little sketchy with the RPMs here:
Lots of corrections and you have traction control active for the entire run. If you just want to run 20PSI and not using MAP scaling I would advise setting the load to torque tables completely stock along with the fuel divisor, the traction control activating like that is usually caused by torque tables being messed up.
Yes, but I'd mainly be concerned about the RPMs there, was it a failed shift?
