968HP Dyno Run with PI & BMS JB4
Scorpstan
111
128
hi
i did some nice dyno runs last week.
for me the first time with the BMS Controller for the PI.
before I had the AIC controller, which was by far not so good.
so what to say....it works very very good
at the end the small 550cc injectors maxed out, and we had to stop at map6 which results in 968hp. time for bigger injectors
here are some logs (map4/850hp+map5/920hp):
big thanks to terry for giving me a few tips about the settings.
Setup:
-335i E92 AT
-Build Engine with closedeck, CP Pistons and Pauter Rods
-Speedtech kit with PT6870
-Mapping by TruepowerSoftware
-selfmade Dual HPFP
-selfmade Stage4 Fuelline Setup with 2x450Walbro
tisdrew
176
89
09 335i 6MT
That's awesome stuff! nearly a thousand wheel and under 30 psi too. Have you done head work or stock head?
DomiN54ik
37
17
BMW E82 135i N54
How much psi and timing for 970 HP with the 6870? Which A/R do you use? seems to fall on its face in high rpms
Scorpstan
111
128
34-34,5,
84AR
6500rpm was the end of the run because trims maxed out and jb went to safty mode. ;-)
The Convert
1,487
1,048
Not to split hairs, but images say 968ps, which google says is 954.xx. Still amazing numbers.
Snertz
61
NY
2011 1M
Cool idea building it into the AC compressor housing. Quite a lot of torque, what's done to the trans?
Scorpstan
111
128
Some secret upgrades inside ;-)
Last year I had some probs at 1100nm.
Hope this year it will hold the power.
Rileyg
60
36
08 e92
Change out that turbine housing for a larger a/r and I bet you see at least 30 more hp.
