Figured I might as well start a thread for this.
I was running pure600s on a stock bottom end. Too much torque, even ramping boost in slowly. I bent a rod. I'm putting it back together with a stronger motor and transmission.
I'll document the build here for all the work.
The motor has the following upgrades:
- heads ported by Headgames
- Schrick low lift cams
- ARP studs
- VAC closed deck
- JE 10.2 pistons
- H beam forged rods
- King bearings
- pinned crank
- cooper ring head gasket
The transmission upgrades consist of:
- Nizpro input / intermediate shaft
- PD clutches
- PD bushes
- Zip kit
I'll be using a Speedtech bottom mount kit with a Precision 6466g2. Should be able to make about 850 to the wheels with this setup. The car runs on straight e85. The main mods for support/power:
- 950cc port injectors
- 2x450 low pressure pumps
- PR coils
- JB4 and PI controller
- 4 port mac solenoid
- 4bar tmap
- VRSF 7.5 HD intercooler
- trans cooler
- secondaries replaced with vibrant resonators
Started taking it apart...
Bearing material in oil...
New engine and turbo ready to go
Pulling this out without venting the AC was a bit of a challenge, but got it done.
I also dropped the subframe so I could go over it with a wire brush and a fresh coat of paint since it has a bit of rust.
The new engine is covered on the right.
Next update will likely be with my transmission build pics as I get time.
- ARP studs
- VAC closed deck
- JE 10.2 pistons
- King bearings
- pinned crank
- PD clutches
- PD bushes
- Zip kit
- PR coils
- 4bar tmap
- trans cooler
