4,332
100-200 KPH Times.
If you're using Dragy, do your runs in 60-130 MPH and then convert your units back to metric later so you can submit to both record books.
Traf
345
198
135i
Full weight e82
Hydra Performance HP800 turbos @ 21psi
E85 DI only
estimated 600hp
6MT - run was 4th gear only.
N54135iAT
37
17
BMW E82 135i N54
Full weight e82
E85 DI only
estimated 600hp
nice im doing 100-200 ~5,8 with 6266 BB and 102 octane pump + meth on 22-23 psi 4th gear only full interior e82 6MT. 3rd 4th gear is around 5.5-5.6 same boost. Hope to get into 4s with E50 mix and 27-28 Psi. did you try 200-250? did that in 4.2 seconds 5th gear only 25 psi pump map
Reactions: Traf
Traf
345
198
135i
what rpm does your run start at in 4th? just trying to gauge how much, if anything, the 800s lose down low
Hum idk, roughly 4K i would say ?
I haven't tried 200-250, i will try :)
Jern54
290
Netherlands
E91 N54 335i
6at ..can still pickup time between 3-4 shift
How did you think to do that?
Your shifting time is very quick compared to mine.
Throttle closure during shifting is also responsible for this.
It closes to 33% in my case at least.
Can you share a log?
Impressive time tho! I still have to manage to dive into 5 sec...
Kimi_N54
17
E92 335 6AT xhp
stock N54
100 200 5.79
Corrected 5.68
HP800 turbo kit
running 24 psi on 93oct + (150cc/min x6) PI meth
7.5" FMIC
30C ambient temps, 80% humidity
1530kg
255/40/17 Nitto NT01s
