Thx
@WedgePerformance for the Map.
But with this settings and raised Torque eff. divisor (fuel) and over 680 Nm reportet i also get Tq. Lim 4.
@trebila: It's clear why you're not getting Tq. Lim 4, because JB4 is doing the exact same thing as MHD is doing to see more than 22,x PSI boost. It's scaling the boost up. With 180 Load +- you are able to get more then 25 PSI.
If i'm raising the Tq. Output on a scaled MHD Map (25 Peak straight) to 900 Nm, i also get NO Limiter.
But yes, you are right. Normally you don't have to give more Tq. Output to the stock tables.
But the reason i did that, is because my gearbox is getting only 520 Nm of torque while my ECU is calculating over 640 Nm.
And then the limiter kicked in.
We would see that if some more people of the beta would have logged with testo.
But me and you are the only guys here posting logs. Sad's that and for me the beta was kind of a fail.
No one here is testing this on a non scaled mhd map with raised tq output.
That's why no one is getting this limiter. Yes, its true, you don't need it to change.
But if xHP is saying they're able of 1000 Nm without limiter and i'm getting the limiter far underneath 1000 Nm, something is not working out.
And NO ONE has logs of 800 Nm+ Tq. output on a NON SCALED map.
BTW: I flashed stock TCU sw to test the limiter. Guess what. 5. Gear Tq. Lim 4 with pulling timing...
Tq. Lim 4 is NOT an ECU caused Limiter, it's from the gearbox. Safe call.
I'm not testing any further due to lack of response from others.
I'll keep my torque tables stock and i'm done.
