x6011 12v Switched for Stand Alone Install.
E90FAN
15
9
Hello :)
Just seeing if anyone can help me find the 12v switched on the x6011 connector in the DME box?
I tried following all of the LSE90 guides but they are using non turbo e9x's, and the x6011 seems to have different colors/pins.
with NewTIS down im hoping someone here knows the pinout for the x6011 :)
also if you know of a better switched 12v please just lmk, this is the last part and I feel like a dumbass at the moment.
SJ_1989
368
299
Illinoisssss
2008 E90 335i
Start with these. If it doesn't have what you need I can look through my Bentley manual when I get back home.
  • 2008 BMW 335i wiring diagram power distribution.pdf
  • 2008 BMW 335i wiring diagram computer data lines.pdf
  • 2008 BMW 335i wiring diagram body control modules.pdf
  • 2008 BMW 335i wiring diagram ground distribution.pdf
  • 2008 BMW 335i wiring diagram DME.pdf
Reactions: E90FAN
E90FAN
15
9
Thank you! @SJ_1989
and for anyone else doing an install on a e9x that started life as a turbo car...
Pin 12 on the x6011 is 12v switched/the correct one to use :)
SJ_1989
368
299
Illinoisssss
2008 E90 335i
No problem. I've been going through these and the Bentley manual quite a bit while wiring my Haltech.
JZ swaps are most definitely allowed. I specifically deleted DI and bought a Haltech so I can swap to one in the future.
  • Love
Reactions: E90FAN
E90FAN
15
9
ok sweet!
I'm almost done figuring out the loom, and have the JZ in to mock everything up, once I'm done doing this diagram, ill make a thread, swear :)
Tg22
ok sweet!
Hey man could I ask you why u took relay out on your later revision?
